Will detonation destroy piston rings?
Here's a quick summary. New motor, with close to 11:1 compression. Car was not boosted yet, and has approx 5k miles on it. Shot 275 across all 4 cylinders under the compression test. Car was detonating plenty, next thing we know the compression is 160 245 245 245. So I'm assuming #1 rings are gone. So we're going to just swap out all 4 rings just to be safe. The car burns up the 10w30 about a 1 1/2 quarts a week. Blown headgasket wouldn't happen minimize the compression on just 1 cylinder would it?
Detonation will usually take out the ring lands too if its severe...so just replacing the rings wont be a viable option if thats the case(assuming that's the problem).
A failing head gasket can also be the culprit and can effect just one cylinder...
You can compression test it and it may give you an idea, but its probably going to require a tear down to be sure...
t-town_ep
12
Feb 20, 2012 04:51 AM
Calvinator
Nov 14, 2004 09:28 PM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
