who uses a filter on there turbo setup?
Old Jul 9, 2002 | 06:56 PM
turboex's Avatar
Default who uses a filter on there turbo setup?
I have a frend of a friend who i plan to call, he lives in calli and has been running a revhard with just the screen on the turbo for over 4years and 120,000 miles. I was told he said that putting a filter on it really killed some power. I plan to call him tomorrow and see how this all goes for him. but who here runs one and what do you think are the +&-. thanks for the input
Old Jul 9, 2002 | 07:11 PM
csufweed's Avatar
Default Re: who uses a filter on there turbo setup? (turboex)
well if you get any dirt or a small rock in the turbo, its said to be enough to kill the turbo. i figure dirt and rocks cant be good for the turbo or the engine so i'd run with a filter.
Old Jul 9, 2002 | 07:24 PM
ceemarun's Avatar
Default Re: who uses a filter on there turbo setup? (csufweed)
the drag kit comes with a weirdo filter. dunno why i said that, butt ok.
Old Jul 9, 2002 | 07:34 PM
Anubyss's Avatar
Default Re: who uses a filter on there turbo setup? (ceemarun)
I have a K&N on there right now but will probably change it a mesh of some sort soon. I've been told by the tuner that a filter on the turbo chokes the turbo a bit. He compared it to putting your hand on a vacuum cleaner (you know how it strains when you block the air).
What ever happened to that guy who had a screen shop or something and showed pics of three different types of mesh screens? I emailed him to see if I could buy some of that stuff but never got a response. I checked out my local Home Depot and they didn't have anything but fine screens. I want something stronger. Anyone know where I can pick one up?
Old Jul 9, 2002 | 07:38 PM
turbologist's Avatar
That slight loss of HP is worth not losing a turbo due to debris or even water gettin in there. I have a K&N cone type filter on there and I made 277 whp @9 psi on a mustang dyno, so its obviously not taking away too much. I wouldnt risk it...
[Modified by drealboostedhybrid, 4:40 AM 7/10/2002]
Old Jul 9, 2002 | 08:48 PM
Smashback's Avatar
Default Re: who uses a filter on there turbo setup? (Anubyss)
Yeah and an air filter chokes an NA engine too. I wonder why all those silly car manufacturers put air filters on there just to kill off a couple of horsepower for no reason
Old Jul 9, 2002 | 09:29 PM
Anthony K's Avatar
New User
Default Re: who uses a filter on there turbo setup? (mplex2000)
Sounds too risky for me. I'll spare the turbo and lose 1hp. I think it's worth it.
Old Jul 9, 2002 | 09:31 PM
GSRgrrl's Avatar
Default Re: who uses a filter on there turbo setup? (Anthony K)
Yup, I'm running a filter.
Old Jul 9, 2002 | 09:35 PM
*Boostwerks*'s Avatar
Why not run a filter?....no room?....MAKE ROOM DAMN IT!!!
Old Jul 9, 2002 | 10:13 PM
Vsm Hatch's Avatar
Wasn't there someone a couple months back who posted a picture of them running a screen and ended up chipping his compressor blades??? It looked pretty nasty..... Anyone have the picture??
Personally, I think losing like 1hp is better then having to risk replace your $500+ turbo.
Old Jul 9, 2002 | 10:36 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
It's not worth risking your turbo for a few ponies. Use Common Sense here.
Old Jul 9, 2002 | 11:20 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: who uses a filter on there turbo setup? (Snafu-Si)
The guy I bought the turbo kit off of 2 yrs ago had a screen. I later convinced him to get an air filter and dyno to see if he lost any hp, the funny thing was he had no hp gain, but gained 5ft/lbs of torque. I think the cooler weather played a big role, but it was only 8deg cooler than the previous dyno 3 months prior. I'll take 5ft/lbs and a safer turbo anyday.
art
Old Jul 10, 2002 | 02:31 AM
Mr. Softee's Avatar
Default Re: who uses a filter on there turbo setup? (Arturbo)
i have no filter... i gotta get it on... just cant fit it. just got turbo on last week though, so bear with me.
Old Jul 10, 2002 | 02:47 AM
CalvitoSol's Avatar
Default Re: who uses a filter on there turbo setup? (94goldjungsr)
how bout if you got one of those ram air style hoods and somehow routed the outside air directly to the cone filter? wouldn't that compensate/push more air into the restrictive cone filter? just a thought
[Modified by theory48, 11:47 AM 7/10/2002]
Old Jul 10, 2002 | 03:32 AM
DSF's Avatar
DSF
Default Re: who uses a filter on there turbo setup? (theory48)
No. The external air pressure relative to the filter would have to be greater than the pressure drop caused by the filter. While not that great, you would still need a signifigant amount of airflow to create that. The only "feasible", acceptable option is to go with the largest filter available. But what do I know, I'm one who voted for "no filter"
Old Jul 10, 2002 | 03:55 AM
CalvitoSol's Avatar
Default Re: who uses a filter on there turbo setup? (DSF)
lol. well ya'll know the saying "better safe..........
Old Jul 10, 2002 | 04:41 AM
int3gra's Avatar
here is the post:
https://honda-tech.com/zerothread?id=219516
Old Jul 10, 2002 | 05:13 AM
CovertFI's Avatar
i am sure the scoop would have to take up most of the hood. because at 10psi you are moving a **** load of air.
Old Jul 10, 2002 | 06:45 AM
VTC_CiViC's Avatar
Default Re: who uses a filter on there turbo setup? (CovertFI)
I rigged a screen attatched to a length of dryer hose running from the passenger headlight housing (removed the light) right to the turbo for an even at Moroso, I then just slapped my regular dirty as sin $20 APCorwhatever filter back on there.. no difference whatsoever.. go figure
Dubs13
Sep 9, 2009 12:24 PM
alexsracing
Jun 30, 2006 04:17 PM
dangerranger21
Jun 15, 2006 08:30 AM
builtB20turbo
Aug 30, 2003 05:43 AM
Elite Hatch
Nov 24, 2002 05:04 PM
