where to get endtanks modified for starion intercooler
Old Jan 23, 2003 | 12:58 PM
jazz215's Avatar
Default where to get endtanks modified for starion intercooler
just wanted to know
where would i take my ic to get the endtanks modified? so the the in/outlets are coming out the sides? also would anyone know how much it usually is to get this done?
Old Jan 23, 2003 | 01:07 PM
LS-hatch's Avatar
Default Re: where to get endtanks modified for starion intercooler (jazz215)
I've heard that JB weld holds just fine for endtanks. Just get some alum. sheet metal, cut it up and JB weld that sucka.
Old Jan 23, 2003 | 01:27 PM
jazz215's Avatar
Default Re: where to get endtanks modified for starion intercooler (LS-hatch)
so i would just cut the pipes from the top of the ic, then close up the holes, then cut out new holes on the sides and use jb weld to put the pipes back on? how stong is jb weld?
Old Jan 23, 2003 | 01:53 PM
rioninja's Avatar
Pretty strong, will hold a lot of pressure. <u>BUT</u>, it cant take a lot of shock. If you smack the piping against something it will crack.
Old Jan 23, 2003 | 01:56 PM
kenbdSi's Avatar
That the same way I did mines. Looks ok too. Like he said it not gonna take not hard shock. I pressure tested mine too, but i havent boosted on it yet.
Old Jan 23, 2003 | 01:57 PM
dmotoguy's Avatar
Default Re: where to get endtanks modified for starion intercooler (kenbdSi)
so would you guys reccomend JB welding endtanks on for a street drivin car?? what about mounting brackets..
Old Jan 24, 2003 | 08:57 AM
jazz215's Avatar
Default Re: where to get endtanks modified for starion intercooler (ballrub)
thnx for info guys.. looks like i have something to do this weekend
Old Jan 24, 2003 | 10:48 AM
mamaboy's Avatar
I'm going to GT Fabrications...they usually only deal with WRX and or DSM, but they're good guys...tig welds of course...give them a call 714-521-6612
their street addy is 6904 Oran Circle Buena Park, CA 90621...use mapquest or something....kinda hard to find, but the head guy used to work at RRE and RRE is pretty damn impressive
Old Jan 24, 2003 | 11:31 AM
ion_four's Avatar
Maybe you could bring it to a radiator repair shop? I'm sure they do alot of aluminum welding. I have also heard of people just bringing them to muffler shops. Do the cutting yourself and supervise while they do it, so they don't dick it up (as seems to happen alot )
Old Jan 24, 2003 | 12:56 PM
kenbdSi's Avatar
Default Re: where to get endtanks modified for starion intercooler (ion_four)
The only reason that I did mine with JB weld ,was that I couldnt find anyone around to weld aluminum. I would recommend getting it welded ,but if you cant there is that alternative.
Old Jan 24, 2003 | 01:20 PM
jazz215's Avatar
Default Re: where to get endtanks modified for starion intercooler (mamaboy)
ill go check out the gt fabrications place, they are only 2 miles from my house. thnx man. should i keep the in/outlets the same size? im using it with the greddy kit for d16z6. i was thinking 2.5 inlet and outlet
Old Jan 24, 2003 | 01:38 PM
LS-hatch's Avatar
2.25" would be better for that setup. The bigger pipes will give you more airflow than you really need but they will increase lag.
Old Jan 25, 2003 | 05:26 PM
dave'sh22a4's Avatar
haha...i just got my starion intercooler done just the way you want it...i wish i knew how to post pic. but i have no clue....its pretty simple...didn't cost that much either....all together with intercooler i spent $300...well good luck...if u need n/e info..p/m
BB6-213
Welding / Fabrication
16
Jun 1, 2007 11:22 AM
19sec beast
May 12, 2005 05:35 PM
80884
May 8, 2005 01:56 PM
Accord94DX
Jun 27, 2003 03:01 PM
TurBoXBirD16
May 29, 2002 10:44 PM
