when you can't lower the engine into the car... lower the car onto the engine [pics]
I finally got the head on the motor and everything bolted together. Theres still a long way to go but a couple of mounts are in and I'm starting to see the end. If anyone is ever thinkind of putting together and entire drag car from scratch just know it takes a LONG time. Motor assembly, tranny work, head assembly, putting it all together, fuel pump, suspensino, wiring, etc etc. Anyway here you go.
We didn't have a hoist so I put the tranny on the blcok and pushed that under the car. Then I put the head on with it sitting in the engine bay (too tall to push it all under). Set the timing, tightened down the crank, and lowered the car onto the engine. The beginning: Modified by trbob16a at 5:50 AM 5/21/2004 |
Re: when you can't lower the engine into the car... lower the car onto the engine [pics] (trbob16a)
Re: when you can't lower the engine into the car... lower the car onto the engine [pics] (Arturbo)
I'm surprised you fit an engine behind that intercooler. Awesome.
Please tell me that that is the Inlinepro manifold, and that it is really mounted like that(compressor towards drivers side)?!?!?! numerous have told me that it cannot be done....
I give your car https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif Very good work... https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: when you can't lower the engine into the car... lower the car onto the engine [pics] (InfamousRS
it is the inline pro manifold, and it can be done https://honda-tech.com/forums/images...es/emsmile.gif. lots of space between the turbo and block when mounted this way. we just need to rotate the compressor housing 90 degrees counter clockwise so the intercooler piping will fit.
Brian |
Please tell me that that is the Inlinepro manifold, and that it is really mounted like that(compressor towards drivers side)?!?!?! numerous have told me that it cannot be done.... I give your car https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif https://honda-tech.com/forums/images/smilies/star.gif Very good work... https://honda-tech.com/forums/images/smilies/emthup.gif YES, it is the inline pro. YES, it is really mounted like that. YES, the short 4" filter fits and you don't have to shave the frame or have an elbow. YES, that is a 60-1 and everything fits like a glove. I got the filter from b18bturbo, I think it was about 30 bucks. [Modified by trbob16a, 10:08 AM 1/10/2003] [Modified by trbob16a, 10:08 AM 1/10/2003] |
Is there plenty(between turbine and radiator) of room for a 3" DP? Can t really tell from any of your pics...
its going to be tight for the downpipe. it can fit, but the bend coming off of the exhaust housing wont be optimal. it may have better fitment if we trim down the fan housing
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D Brian |
I think so. I'll let you know for sure in a couple of weeks when the car goes in for some fabrication, including downpipe and rollcage.
It looks like there is definitely room for the standard 2.5 to 3" flare downpipe. We were wondering the same thing but it looks like it will be fine. edit: removed picture, see post above [Modified by trbob16a, 10:17 AM 1/10/2003] |
Hey, could you do me a really good favor and get a good shot of the space between the rad. and turbo?
I'll try and remember to next time i am over there (most likely Sunday, after nathan has gone to some ballet's or play's, damn sissy https://honda-tech.com/forums/images...s/emsmilep.gif)
Brian |
It comes with having a girlfriend, and I don't mind it.
/who is putting on a tie as I type OK back on topic. Yes, we'll try to get a better picture for you. |
You've been together long enough, you can start treating her like dirt now https://honda-tech.com/forums/images...s/emsmilep.gif
Brian -who had the bright idea of how to get the motor in the car (the marketer out does the engineer!) |
Very nice i think i want an inline pro manifold
Wicked setup I must say. And very different install. What size and brand intercooler is that btw it looks so sexy right there..!!?
I got one, trust me, you want one https://honda-tech.com/forums/images...es/emsmile.gif
ingenuity...hell if it works, use it https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif
looks like its coming along well... https://honda-tech.com/forums/images/smilies/emthup.gif
So fresh, so clean....good work so far nate. I'll hopefully see you Brian and the car later this month. Peace
Re: when you can't lower the engine into the car... lower the car onto the engine [pics] (Jay-C)
I like, i like, alot. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif Looks sweet. I am drooling.
That sir... If fucking awesome... HAHAHAHAH
Re: when you can't lower the engine into the car... lower the car onto the engine [pics] (631 Teggy)
Re: when you can't lower the engine into the car... lower the car onto the engine [pics] (boostedb20
Dayuum bad a-- ph00!
