When is it necessary to buy axles?
Old Dec 2, 2002 | 05:05 PM
AVATAR's Avatar
Default When is it necessary to buy axles?
Is there a spefic horsepower that poeple have found the stock axles to reak at, or is it more of a problem just with slicks. I really dont want to buy new driveshop axles if I dont need to. Thanks
[Modified by AVATAR, 2:06 AM 12/3/2002]
Old Dec 2, 2002 | 05:12 PM
AVATAR's Avatar
Default Re: When is it necessary to buy axles? (AVATAR)
Sorry, I posted then searched. My bad! It seems like if you have anything that engages really rough (3/4 puck clutch) they will break. Anyone know of any smooth engaging clutches?
Old Dec 2, 2002 | 05:26 PM
sweet's Avatar
not really sure what smooth is, but my CM stage 3 clutch is great. it holds the power and engages smoothly, IMO.
Old Dec 2, 2002 | 05:41 PM
PM-Performance's Avatar
Default Re: When is it necessary to buy axles? (sweet)
you need new axles when your sitting on the line and you have tranny fluid leaking out on the track , that the best indication i know
Old Dec 2, 2002 | 05:44 PM
blkDOHCsol's Avatar
New User
Default Re: When is it necessary to buy axles? (itr206)
its necessary when you break one... anything over 300whp it would be a good idea to have some spare stockers laying around when you go to the track
Old Dec 2, 2002 | 06:03 PM
AVATAR's Avatar
Default Re: When is it necessary to buy axles? (blkDOHCsol)
I'm trying to steer clear of the latter of the 2 statements made if at all possible I guess stockers are the way to go. . .
Old Dec 2, 2002 | 06:46 PM
sweet's Avatar
i've been told that the stock ones should handle up to 220 WHP when launching at the track. though for how long they last depends on how often and whether or not you're using slicks of some kind. the slicks get wreck axles quick as can launching at 4 or 5K often. driveshaftshop axles are nice if you have the need to upgrade.
Old Dec 2, 2002 | 07:03 PM
AVATAR's Avatar
I read a couple of posts by ninesecrx and he said he was making some nasty power w/ slicks and OEM axles w/o snapping problems, anyone have any other or similiar opinions?
Old Dec 2, 2002 | 07:59 PM
yellowsub's Avatar
What kind of car do you have.
Old Dec 2, 2002 | 08:04 PM
AVATAR's Avatar
Default Re: When is it necessary to buy axles? (yellowsub)
A 2000 Civic Si.
DIRep972's Avatar
Smarter than you
axles will break because of bad driving, harsh clutch engagement, bad suspension that cant put power down/sends all power to one side, wheel hop, too lall of slicks etc. Run stock axles, keep spares around just in case and if u start to break them frequently upgrade.
Old Dec 2, 2002 | 08:18 PM
yellowsub's Avatar
Default Re: When is it necessary to buy axles? (DIRep972)
Cant you put in some gsr axels?
Old Dec 2, 2002 | 10:35 PM
ninesecrx's Avatar
I ran stock gsr axles in my car making over 550whp and I have a friend with a race car making that power as well with stock axles and never broke his either. Just depends on how the car is driven and how its setup. I used to break the diffs. before I would break an axle.
Old Dec 2, 2002 | 11:38 PM
V-SPEC 1's Avatar
Default Re: When is it necessary to buy axles? (ninesecrx)
I guess you better off braking axles rather than diff. The diff, is more expensive.
Old Dec 3, 2002 | 04:19 AM
Default Re: When is it necessary to buy axles? (boostedb20vtec)
i never broke any yet, i was pushing about 300 whp outta my R and on slicks launching at 7k+ and still on the stocks. 2seasons worth of racing on em so far and a **** load of daily driving .
Old Dec 3, 2002 | 04:29 AM
turbotypeR@SPEC's Avatar
25 Year Member
if you pre-load the clutch,they will not break.pre-load the clutch meaning do not put your foot on the floor.let it out until right before it engages and then let it go.try to let the pedal follow your foot,not just snap it.i broke about 5 sets before i was told this.
Old Dec 3, 2002 | 08:50 AM
sweet's Avatar
good info to know!
Old Dec 3, 2002 | 08:52 AM
yea but isnt preloading bad for the clutch ? like big time ?
i just went to the line and dropped it like its hott .
Old Dec 3, 2002 | 09:19 AM
austrian type-R's Avatar
Turbo + Slicks + AutoX = broken driver side axle.
Old Dec 3, 2002 | 10:22 AM
hondaswaper's Avatar
Default Re: When is it necessary to buy axles? (austrian type-R)
when you get 26"s or a dual disc clutch ...........what ever comes first.........
Old Dec 3, 2002 | 11:08 AM
AVATAR's Avatar
Default Re: When is it necessary to buy axles? (hondaswaper)
Wow I didnt think I'd get so many replies, usually after I post the thread "mysteriously" dies Thanks for the info! and we'll see how long the stockers last.
Old Dec 3, 2002 | 11:54 AM
ninesecrx's Avatar
my buddy ran stock axles with a clutch masters twin disc with stock axles too. Then he put a 26 tall tire on and upgraded to dss stage 3's and has had no problems either.
Demonis
Honda Civic (2006 - 2015)
Feb 25, 2007 05:35 AM
ek9800
May 19, 2005 12:17 PM
Dohcvtec59
Jul 28, 2004 08:22 PM
91glassycrx
May 17, 2004 07:40 PM
whitemike1644
10
Dec 22, 2002 02:23 AM
