When do you need bigger injectors/
Old Nov 8, 2002 | 08:19 PM
Fatty_1775's Avatar
Default When do you need bigger injectors/
When do you need to upgrade your fuel injectors? I have a second gen B16 with a stage 2 revhard turbo kit with stock internals and injectors. Running at 9 psi. Thanks.
Old Nov 8, 2002 | 08:22 PM
AlphaKennyWun's Avatar
Default Re: When do you need bigger injectors/ (import_racer)
you should have replaced them already
Old Nov 8, 2002 | 08:23 PM
Default Re: When do you need bigger injectors/ (SO3Burner)
replace at anything over 7-8 psi or run the risk of leaning out and breaking something.
Old Nov 8, 2002 | 08:25 PM
MiraiZ's Avatar
When the duty cycle reaches 80% or more at a relatively low rpm...
[Modified by MiraiZ, 2:25 PM 11/9/2002]
Old Nov 8, 2002 | 09:11 PM
BoostedH23a1's Avatar
Default Re: When do you need bigger injectors/ (MiraiZ)
how can u tell that.
Old Nov 8, 2002 | 09:15 PM
MiraiZ's Avatar
Default Re: When do you need bigger injectors/ (BoostedH23a1)
My stand alone can tell me at what duty cycle i'm at...you can get something like the Apex AFC, which will tell you your duty cycle
Old Nov 9, 2002 | 12:20 AM
skilzz's Avatar
investing in something just to tell you duty cycle is not neccessary and the AFC doesn't tell duty cycle anyway. You need to invest in a air/fuel gauge at the minimum to see if your running lean/rich under WOT...or a J&S safeguard that detects detonation. If detonation is present under wide open throttle or part throttle at whatever boost and RPM then you need more fuel. More fuel via an adjustable fuel management system and/or larger injectors if the stock ones are unable to supply the needed fuel.
Old Nov 9, 2002 | 05:51 AM
Fatty_1775's Avatar
Default Re: When do you need bigger injectors/ (skilzz)
Adjustable fuel management systems, what types are available? Especially on a limited budget? Thanks for your help guys!!!
Old Nov 9, 2002 | 06:15 AM
damnit i want a s200b but i got no money
Old Nov 9, 2002 | 10:26 AM
skilzz's Avatar
well it depends on how much more boost your trying to run. Complete stand alone system can be had from http://www.hondata.com. It all depends on your needs.
Acidcrakker
Nov 30, 2007 05:01 PM
inkong
Aug 17, 2007 06:05 AM
2000d16y7
Jul 16, 2007 01:49 PM
DarkDragon
May 20, 2005 03:18 AM
asianspeed
Sep 4, 2002 06:22 AM
