What's the pump gas limit on a d16?
Old Jul 1, 2006 | 10:04 PM
mike93boost's Avatar
Default What's the pump gas limit on a d16?
just wondering what the limits are on a d16 running 93 octane?
Old Jul 1, 2006 | 10:40 PM
Default Re: What's the pump gas limit on a d16? (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">what compression? meth/water injection?</TD></TR></TABLE>
9.0:1 cr
no meth/water injection
Old Jul 1, 2006 | 10:58 PM
tony1's Avatar
Default Re: What's the pump gas limit on a d16? (mike93boost)
It's not that simple. There are a lot of variables that determine the knock limit of an engine.
Old Jul 1, 2006 | 11:00 PM
Default Re: What's the pump gas limit on a d16? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">It's not that simple. There are a lot of variables that determine the knock limit of an engine.</TD></TR></TABLE>
yes, i know. but just was wondering what the rough guesstimate is. my guess is 350whp?
Old Jul 2, 2006 | 05:52 AM
oscarmayer's Avatar
I clocked 374@20psi and
Old Jul 2, 2006 | 11:03 AM
adseguy's Avatar
So with that said it's gong to be 348whp.
I mentioned this in the last post you did about this EXACT SAME SUBJECT , but first off look at torque! Horsepower is an equation using using torque and revs. Torque is a read out of the engines work. I like to switch to race gas for cars at 300wtrq. I'd say if the engine is being efficient (ie: making lots of power for every lb of boost) and you stay conservative you can easily go above that. AGAIN, like I pointed out in the other thread, with a d16 engine you will be making tons of torque (like an LS) even with a built head, so just watch out. If you have a reliable method of listening for knock I would use that too for some added help if you run into pump gas limit knock .
edit: So are you gonna let me tune this thing or what?
Old Jul 2, 2006 | 11:15 AM
Default Re: What's the pump gas limit on a d16? (adseguy)
there's alot of things i havent decided on yet. race gas or pump gas. are the only problems of running 100% leaded gas is that the wideband and narrowband sensors dont last very long? is that it? or maybe i should do a 93/110 mix?? we have 110 at the pump here in holts summit.
i have everything ready. im just waiting on the head and block right now. as soon as i get that ill have it together in no time. then i need to decide on how to break it in. then get her tuned. havent decided on a tuner. i want the best tune available. texas, chicago, kansas, or you.. how much experience do you have and how many vehicles have you tuned and to what power levels? i obviously want to be street and dyno tuned. there's a dyno dynamics in columbia.. i know the owner.
EDIT: btw, check out my forum, http://www.midmosr.com
look under the image gallery for my setup progress.
1SiC 3DR
Southeast
Feb 21, 2008 02:05 AM
oneprelude
Jan 3, 2008 03:52 PM
sky9
Mar 23, 2007 04:27 AM
cyang08
Mar 13, 2006 09:21 AM
CarbonCreations
Nov 30, 2003 05:40 PM
