What's the Max WHP on 91 Octane?
I'm going to assume you mean a pump-gas 4-banger turbo Honda?
every post turns into a flame war..jesus h.
I think its gotta be around high 300's...maybe even 400. Im shooting for 400 on pump....dont know if it can be done..but I'm sure it has been done before.
Since you're having problems getting answers....I'll try and help...Keep in mind, I'm still a noob myself
But your question has too many variables for a specific answer. It depends on your setup. turbo size, max psi, fuel management...
For example, you can get a lot more power on 91 octane running Hondata and a flat fuel curve then you could with an FMU and check valves all over the place.
Sorry if that didn't help..What you can do is search around for some "dyno" posts. Guys normally list the type of gas they run.
But this isn't setup dependent. I want to know what the most power people have seen out of a turbo honda running 91 octane. Or what the most power you "can" make.
sorry bout that....then just search under "dyno"...I just tried it and pulled up a ton of posts. I'm sure some of them list what gas they use...If not, just IM that person and ask.
Smarter than you
most of the tuners ive talked to stop at 300whp on stock motors w/ 93 octane. with built motors they push it further, to 350whp. on 91 octane id assume it would be a little bit less. maybe 275 on a stock motor, 325 on a built motor. im sure u could push it further, but id prefer to keep it safe.
Yo there is a gas station neer me that has 104 octane... Like woah!!! I'm afraid if I fill'er up my car will never be able to run 93 again
EDIT: it's aeronautical fuel
[Modified by 631 Teggy, 9:30 PM 2/25/2003]
But this car is a daily driver going for 350whp on 91 Octane.
This is the setup:
Engine:
* JDM b18c
Block work:
* GE Gorilla Sleeves, 84mm bore
* JE 84mm 9.5:1 pistons
* Eagle Rods
* ARP Head studs
Head Work:
* Portflow head porting
* Portflow dual valve springs
* Portflow Ti retainers
* stainless steel valves
Turbo Setup:
* Rev Hard Cast turbo manifold
* Precision SC44 .63 a/r
* FMIC 32x8x3.5
* Turbosmart 35mm wastegate
* 2.5 inch downpipe
* HKS SSQ BOV
* 2.5" Charge pipe
* 2.25 Intercooler Piping
Induction:
* JG Intake manifold
Fuel System:
* MSD 65lb Injectors
* Resistor Box
Exhaust:
* 3.0" Test pipe/Flex
* 3.0" Catback
Electronics:
* Hondata s100 Engine Management
* Blitz SBC i-D Boost controller
* Blitz Power Meter i-D
Looking for 350whp on 91 Octane @ whatever boost it takes to get there safely.
Engine:
* JDM b18c
Block work:
* Eagle Rods
* ARP Head studs
Head Work:
Turbo Setup:
* FMIC 32x8x3.5
* 2.5 inch downpipe
* HKS SSQ BOV
* 2.5" Charge pipe
Induction:
Fuel System:
* Resistor Box
Exhaust:
* 3.0" Catback
Electronics:
i have a very similiar set up being finished up right now(but with RS sleeves, garrett, 550's). it's going to be tuned for 91 octane, it should be ready by the end of this week or beginning of next. i'll let you know.
ive heard of some dsm and nissans making 400-430whp on 94 octane pump (both 2litre turbos). There was a thread about this a few months ago...dont remember what it was about tho.
I would expect here on crappy 91 the power is goign to be alot less. Have you though about propane injection or water injection?
liam
liam
RyanAutry:
I thought you were a die-hard B16 guy? I thought you were all about boosting your B16, so whats with the JDM B18C. Just curious...
lol, no. I'm just a cheap bastid'
That's why I boost a b16. $500 Long-blocks is a good thing.
If I could afford a b18c. It would be done.
This is my best friends setup.
