whats the flow rate in cc's on these injectors?
d16 stock injectors = ?
b16 stock injectors = ? b18 stock injectors =? thanks in advance MARLON |
Re: whats the flow rate in cc's on these injectors? (SolidSpruce)
240
240 240 |
Re: whats the flow rate in cc's on these injectors? (Giuseppe)
its all the same of them? im not sure about that....
240 240 240 240 240 Sonny |
Re: whats the flow rate in cc's on these injectors? (Sonny)
i just called honda, and they have different part numbers on the injectors between the series of engines.....he said the ARE NOT the same flow rate, but the system dosnt give him such detailed specs, but that indeed that are not the same.
come on guys |
they are all the same flow rate....they just may have diff plugs thats why the part # is diff...
Trust us...they all have the same flow <U>rating</U>. They will flow differently in each respective vehicle due to different factory fuel pressure settings.
They have different part numbers because they are different parts given the model year. OBD-0, OBD-1, OBD-2...and there are some physical differences as well. Some use thicker or thinner seals at the manifold. ....but they all flow at 240cc/min at 43.5psi fuel pressure. [Modified by DSF, 2:14 PM 7/10/2002] |
anyone know the flow rate of non turbo eclipse/talon injectors?
Re: whats the flow rate in cc's on these injectors? (DSF)
They all flow the same, 240cc/min
Re: whats the flow rate in cc's on these injectors? (technine)
anyone know the flow rate of non turbo eclipse/talon injectors? |
VEHICLE Injector Types Flow Rate
1988-91 Civic si/crx si Peak and hold 240cc 1992-95 Civic si/ex Saturated 240cc 1996-00 Civic Saturated 240cc 1990-91 Integra Peak and hold 240cc 1992-00 Integra ls/gsr/type R Saturated 240cc 1992-96 Prelude non-vtec Peak and hold 240cc 1992-96 Prelude VTEC Peak and hold 345cc 1997-up Prelude VTEC Saturated 280cc 1991-up Sentra se-r/200sx se-r Saturated 265cc 1991-up MR2 Turbo Peak and hold 440cc 1988-91 Supra Turbo Peak and hold 550cc 1993-up Supra non -Turbo Saturated 315cc 1993-up Supra Twin Turbo Peak and hold 550cc 2000-up Celica GT-S Saturated 310cc 1990-up Miata 1.6 liter Saturated 215cc 1993-up Miata 1.8 liter Saturated 240cc 1993-up RX-7 Twin Turbo Saturated 550cc/850cc 1990-96 300zx Twin Turbo Saturated 370cc 1991-up 3000GT VR-4 Peak and hold 350cc 1989-up Eclipse Turbo Peak and hold 450cc |
Re: whats the flow rate in cc's on these injectors? (inspyral)
thanks DSF
http://images.zeroforum.com/smile/emthup.gif http://images.zeroforum.com/smile/emthup.gif http://images.zeroforum.com/smile/emthup.gif very useful info.
[Modified by LiL_Kid, 12:25 AM 7/11/2002] |
Re: whats the flow rate in cc's on these injectors? (LiL_Kid)
cool, thanks for all the info guys!!
