what turbo for jdm gsr?
i'm planning on boosting my '94 JDM B18C.. 10.6:1 compression.. all the basic bolt on's.. blox intake mani.. stock internals.. only planning on pushing ~6psi for the time being.. maybe bump it up next year after some building.. this is also my daily driver..
what would be a good turbo for me? (size/brand.. i'm new to honda fi) |
Re: what turbo for jdm gsr? (AlxSiR7)
Re: what turbo for jdm gsr? (ben@importparts.com)
..i already have everything i need.. but a turbo. i bought a t3/t4 60trim, but decided that was too big & sold it. any other suggestions?
How much power do you plan to ultimately run?
i have the t3/t4 60 trim i loved it until i broke my ring lands https://honda-tech.com/forums/images...s/emthdown.gif
Re: what turbo for jdm gsr? (SoSlo)
right now im looking for ~250-260whp w/a .4bar spring (~6psi).. if/when i build the motor next spring.. drop the compression.. maybe 15-17psi. but thats a HUGE maybe.. most likely going to leave it at a low boost.
SoSlo: about what rpm did the 60trim spool up for ya?? |
Shoulda just stuck with the 60-trim, you'll be hard pressed to make 250 WHP at 6 psi on anything much smaller.
Re: what turbo for jdm gsr? (boosted92)
i'd slap a sc61 on a jdm gsr no doubt
https://honda-tech.com/forums/images...es/emsmile.gif |
it was fully spooled at like 4400 but i had a large manifold leak that i didnt fix until after i plew my motor
Re: what turbo for jdm gsr? (GOLDBERG)
i still have the 60trim.. *trying to sell it.
*just read up on the sc61.. sounds nice.. any other suggestions? Modified by AlxSiR7 at 9:51 PM 6/9/2005 |
SoSlo: it spooled @ 4400 with the mani leak??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 »</TD></TR><TR><TD CLASS="quote">right now im looking for ~250-260whp w/a .4bar spring (~6psi).. </TD></TR></TABLE>
260whp at 6psi is the same as 260whp at 10psi or 260whp at 20psi https://honda-tech.com/forums/images/smilies/emwink.gif |
ya i had a dime sized hole in the mani and it hit 11psi at just under 4400 rpm
Re: what turbo for jdm gsr? (ITR981002)
I would say hold on to the 60 trim turbo and just use that. If you are running it off just your WG spring, then you should be pretty close to your initial power goal of 250-260 WHP. What are your future power goals? I know you said 15-17 PSI, but how much power are you looking to make?
Re: what turbo for jdm gsr? (BlueShadow)
so just use the turbo i already have?.. i've had people tell me it could take up to 5000rpms to spool up.. then others say only around 3500.. as far as "power goals".. i don't really have a specific goal. i dont street race and i go to the track maybe 3 times a year just to have fun. i already had my race car (see sig).. just looking for a garage project this summer. 300whp would be nice though! i just dont want to loose reliability of my daily driver. that sc61 is a little expensive.. maybe i should just hold on to this t3/t4 60?? https://honda-tech.com/forums/images...es/emsmile.gif
I'd like to know how it turns out for you, cuz I'm trying to decide now what motor I want to start building. I' m currently run a JDM B18C in my hatch; however, I picked up 99 LS to build for a turbo and have not done much with it. I've heard alot of people are having success building the B18C so I'm leaning towards build it and selling the LS. I know that 10.6:1 is not the best to boost, so I'm looking at new pistons and rods but not sleeving. Any thoughts?
Rgrs B |
Re: what turbo for jdm gsr? (Mr_Eg_Hatchback)
i dont know man.. like i said im new to boostin hondas. i'm not building mine at all, but also keeping the boost low. you'll be fine if you build her though!
im running the stock internals and i loved the 60 trim on my jdm gsr
just need to fix the tune so i dont break more ringlands https://honda-tech.com/forums/images...s/emthdown.gif |
hm.. maybe ill just save some money and keep this. its brand new.. dont feel like spending the extra 150-200 for the sc61 anyway.
