What is this? Rod pics, something wrong
Old Oct 4, 2006 | 03:36 PM
MAFDARK's Avatar
Default What is this? Rod pics, something wrong
any idea? just pulled them from my D:
Old Oct 4, 2006 | 03:41 PM
non-VTEC's Avatar
Default Re: What is this? Rod pics, something wrong (MAFDARK)
looks like someone used a torch/heat on the small end of the rod? maybe they though it was a pressed fit piston pin?
Old Oct 4, 2006 | 03:42 PM
MAFDARK's Avatar
i dont think so.
Maybe i can explain better than the pics do. The grey is some type of deposit. its built up. Looks as if i could sand or file it off.
Im assuming the color change of the metal is from the friction from something
Old Oct 4, 2006 | 03:43 PM
agrn93ls's Avatar
sorry if this dont help as in if you know this much already, but that is from heat ALOT of heat. i would think red hot. would appear lack of lubrication or maybe sizing of the rod to wrist pin was incorrect. something of that nature, how does the wrist pin look, and the piston where the wrist pin goes in??? look like that during assembly???
Old Oct 4, 2006 | 03:44 PM
MAFDARK's Avatar
Both look fine. Which confuses me further.
Old Oct 4, 2006 | 03:45 PM
agrn93ls's Avatar
Default Re: (MAFDARK)
yeah im with you now, would you know if this was before or after assembly/running engine.
Old Oct 4, 2006 | 03:46 PM
MAFDARK's Avatar
engine ran for less than4k miles. Only thing out of the norm is some very slight rod knock and a couple of blown gaskets.
Old Oct 4, 2006 | 03:57 PM
agrn93ls's Avatar
well i dont know so im not helping but it would be worth alot to know if it happened during assembly like someone heated it or if it happened running. if someone did it no big deal, but if the engine did it there is a problem. sorry for not helping anything
Old Oct 5, 2006 | 05:02 PM
hybrid_KJ's Avatar
Default Re: (agrn93ls)
I had a piston melt on a friends motor due to a igniter failure and it deposited on the rod just like that. Check you pistons.
Old Oct 5, 2006 | 05:18 PM
MAFDARK's Avatar
pistons are mint.
Old Oct 5, 2006 | 05:47 PM
Jared's Avatar
what kind of pistons?
Old Oct 5, 2006 | 06:24 PM
TRAN's Avatar
Default Re: (Jared)
you melted a piston... if you didnt, was the rods brand new on this current motor?
Old Oct 5, 2006 | 06:25 PM
MAFDARK's Avatar
i was just wondering that. IM gonna ask the person i bought the motor from.
Rocket
43
May 6, 2009 06:59 PM
EFstyle
Apr 29, 2008 05:29 PM
2point2
Welding / Fabrication
Jan 17, 2007 06:02 PM
edo
Jul 15, 2005 09:16 AM
hybridb18
Aug 8, 2003 07:28 PM
