What are normal compression test #'s on B18C1's ?
Old Jan 31, 2003 | 05:45 PM
V8 BAIT's Avatar
Default What are normal compression test #'s on B18C1's ?
The reason I ask is that I have done compression tests on my 99 GSR motor on at least three different occasions and when it ISN'T blown it shows around 150 psi in all 4 cylinders..., is that abnormally low for a GSR which is internally stock?
Old Jan 31, 2003 | 05:54 PM
ZentraediEK's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (V8 BAIT)
had mine done last week and it read 200, 200, 208, and 210. But mine is a 2000 GSR and i've only been running 8psi for about three months.
Old Jan 31, 2003 | 06:08 PM
Happyman's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (ZentraediEK)
180-220. In that range
Old Jan 31, 2003 | 06:19 PM
V8 BAIT's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (Happyman)
how many times did you crank for your tests. I always stop at 5 cranks.
Old Jan 31, 2003 | 06:24 PM
Flamenco-T's Avatar
my stock was 210's, with 9.8: CR is 200.
i stopped when the needle stopped moving
stan
Old Jan 31, 2003 | 06:36 PM
dustin's Avatar
Should be over 200psi in all cylinders...
Old Jan 31, 2003 | 06:40 PM
GSRrR's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (dustin)
before the snail was put on, i tested it and it had about 190. 95 with about 90K on motor.
yours seems kind of low. did you step on the gas pedal all the down while turning the ign key?
Old Jan 31, 2003 | 06:41 PM
V8 BAIT's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (GSRrR)
gas pedal down. 99 GSR with only 28000 miles
Old Jan 31, 2003 | 06:45 PM
V8 BAIT's Avatar
I guess this leads to the question, Why? What causes a motor to have such low compression when it is internally stock... I know my altitude has a little to do with it , but not 50-60 psi worth.
Old Jan 31, 2003 | 06:47 PM
dustin's Avatar
What elevation are you at?
Is the motor warm?
Did you disconnect the injectors/pull the ecu fuse? (you don't want fuel in the cylinders)
Crank it until the needle stops moving. Compression testers are "peak pressure" gauges.
Dustin
Old Jan 31, 2003 | 06:58 PM
Cyber ITR's Avatar
where about is the injector fuse ?
is it under the bonnet inside the black box near the battery ?
Old Jan 31, 2003 | 07:01 PM
Flamenco-T's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (VTEC_SiR)
in the black box by the battery, it is the 15amp fuse, looking from the front of the vehicle, it's the top left corner fuse
you can disconnect the distributor harness as well
Old Jan 31, 2003 | 07:59 PM
AlphaKennyWun's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (Flamenco-T)
Old Jan 31, 2003 | 08:15 PM
95c1v1cs1's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (S03Burner)
I had 180(+-5) but my motor was built 1,500 miles ago too. And it has 9.0:1 pistons in it. Those numbers seem really low. Try adjusting your valves, i think that improves your numbers. I think... A warm car also improves your numbers.
Old Jan 31, 2003 | 09:19 PM
V8 BAIT's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (95c1v1cs1)
I'll try the valve adjustment. It was at normal temp every time I tested it.
Old Jan 31, 2003 | 09:38 PM
Cyber ITR's Avatar
the only 15amp fuse i have is only for the ECU
oh btw this is for jdm itr
Old Jan 31, 2003 | 09:41 PM
Cyber ITR's Avatar
whoah 180ish with 9:1 pistons , my damn jdm b18c (1) with 10.6:1 only have bout 190ish , must be almost blow up
Old Feb 6, 2003 | 09:23 PM
V8 BAIT's Avatar
Can anyone confirm whether or not a valve adjustment can makea difference in the numbers ?
Old Feb 7, 2003 | 08:32 AM
dustin's Avatar
Nope.
Old Feb 7, 2003 | 09:32 AM
94TealGSR's Avatar
Not that I'm sure it helps, but my B18C w/ USDM ITR pistons runs about 260 all the way accross.
Old Feb 7, 2003 | 09:37 AM
speedymon's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (94TealGSR)
Mine was 230 psi across the board. Throttle open and warm. 102k on the odometer.
Old Feb 7, 2003 | 10:06 AM
Farnsrocket's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (speedymon)
I think the variances between peoples cars have alot to do with the different compression testors.
Old Feb 17, 2003 | 11:57 PM
irev210's Avatar
Default Re: What are normal compression test #'s on B18C1's ? (Farnsrocket)
yes, different compression testers are not all created =
Old Feb 18, 2003 | 05:56 AM
tony1's Avatar
A vavlve adjustment can through off a compression test. If they are too tight then the valves won't seat all the way and compression will be low. You could also do a leakdown test to see where the pressure's going.
Old Feb 19, 2003 | 12:19 AM
jasonb's Avatar
only if your valves are staying completely open
