what do you think about MSD Pro Distributor?
Old Jul 5, 2008 | 12:53 AM
gsrt's Avatar
Default what do you think about MSD Pro Distributor?
what do you think about MSD Pro Distributor? thanks
Old Jul 5, 2008 | 11:35 AM
Tchleung's Avatar
I run it as well as alot of people and it works great, idle is alot better with this then my others. Word of advice if you search tho, the rotor and cap screws are sometiems a problem and are loose from the factory so right away, open the cap up and make sure the rotor screws are right and retighten the cap. I put a light light dab of loctite on them too and it's never given me problems.
Old Jul 5, 2008 | 07:10 PM
gsrt's Avatar
Default Re: (Tchleung)
thanks for infor.
anyone use it for 800hp++
Old Jul 5, 2008 | 08:02 PM
RedneckRicer's Avatar
for the price.. Dizzy... Ignition module and a new coil.. stick with stock and M&W pro 10 with crane coil.
Old Jul 6, 2008 | 03:27 AM
gsrt's Avatar
Default Re: (RedneckRicer)
can msd distributor work with hondata S300? thanks
Old Jul 6, 2008 | 11:30 AM
Tchleung's Avatar
I'm running mines with S300 no problems here
Old Jul 7, 2008 | 07:17 PM
Tchleung's Avatar
As requested by gsrt:
Shows how the coil bolts ontop of the ignitor with heat sincs
And my useless picture just cause
Old Jul 7, 2008 | 09:24 PM
that catch can is pretty umm interesting got any more pix of it.
Old Jul 7, 2008 | 09:33 PM
Tchleung's Avatar
Mm no not really. it's just the same design as most of the open breather cans out there like T1 race has except since my car has limited space, we decided to not use filters and use a flat mesh insert instead to save on alot of space. It's basically a rectangle box with some tapers here and there and baffles and holes
4 fittings on top, 1 on bottom for block vent which also acts as drainback
Old Jul 8, 2008 | 04:58 AM
boosted hybrid's Avatar
Default Re: what do you think about MSD Pro Distributor? (gsrt)
The distributors work really well. You have to take them apart and tighten any of the screws inside with loctite. Also, the pin that holds the distributor "button" on shears off. If you replace the pin with an OEM honda one, there are no issues. I have made a ton of power with the MSD distributors and not had any issues after they were gone through to make sure nothing was loose and the pin was changed. You can tell a difference running one compared to an OEM distributor with the Honda ecu, and they take care of all the stat sync issues with AEM at high rpms.
Old Jul 8, 2008 | 06:20 PM
gsrt's Avatar
Default Re: what do you think about MSD Pro Distributor? (boosted hybrid)
which pin? do you have picture of it? thanks
Old Jul 8, 2008 | 07:14 PM
swapit's Avatar
im running just the msd dizzy no ignitor with a digital6 box and hvc coil.and it diff works great with the aem.jeff tuned my car see sig.
def use med loctite with all the bolts and espec. the rotor screws.take a oem dizzy pin that holds the gear that goes into the head for the cam turn and replace the msd one or it will shear itself.
Old Jul 9, 2008 | 06:31 AM
vtekthis's Avatar
Default Re: what do you think about MSD Pro Distributor? (swapit)
i run it... stock pin over 2 seasons over 800hp, with m&w pro 10 and crane coil ---flawless
Old Jul 9, 2008 | 04:36 PM
gsrt's Avatar
Default Re: what do you think about MSD Pro Distributor? (vtekthis)
thanks for all information
Old Jul 18, 2008 | 11:38 AM
Muckman's Avatar
Moderator in Chief
I did my homework on the MSD Pro-Billet Dist, took mine apart and make sure everything was tight. Exctly 24 miles later the rotor came loose on the dyno and tore up the cap.
MSD replaced cap and rotor under warranty.
They told me the torque specs are 20 inch/lbs and blue loctite.
xlusiveracer
44
Apr 3, 2018 04:59 PM
BreakMaster
Sep 9, 2004 11:49 PM
dyg2001
Feb 24, 2004 09:38 AM
ernald711
Mar 4, 2003 07:26 AM
