WHat do you guys do with oil and filter?
Do you guys fill up your oil filter with fresh oil before installing? I've always been taught to always fill up the oil filter with turbo cars from the factory. On our turbo hondas, I've tried half way and it still spills. I've also tried no oil at all and they've ran just fine. SAme with some DSM's
What do you guys do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">This makes it much easier to not spill... and I fill it up, this thing takes almost a quart on its own.
Where can that be purchased?
</TD></TR></TABLE>Where can that be purchased?
If you pull the ecu fuse and crank it until the oil light goes off then it'll do the same thing w/o making a mess. It's just a matter of getting oil pressure up before starting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">theyre just the standard 20x1.5 (i think thats the right thread) relocator kit on summit right?
do you have a PN?</TD></TR></TABLE>
I don't have part numbers, I did it months ago.
20x1.5 fits the landing on the block
the filter mount comes with 3/4x16. You use a Fram PH8A or equivelant (its for a Ford V8) I think you can also use a PH16, which is a shorter version of the PH8.
i filll it halfway and never spill it
u have to pour in oil, then angle the filter and keep turning it around, until the filter sucks all the oil into the filter material
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">i filll it halfway and never spill it
u have to pour in oil, then angle the filter and keep turning it around, until the filter sucks all the oil into the filter material</TD></TR></TABLE>
Yep. Fill it half way and let the filter element soak up the oil. Never spills for me.
I just take the ecu fuse out and crank it till the oil light turns off like Tony said. 100% oil pressure right off the bat is always a good thing. Where I work, the emchanics just put the empty filter on. and crank ti voer and let it idle for 5 secs or till the oil light turns off then rechecks oil. as you should always after doing oil changes anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">If you pull the ecu fuse and crank it until the oil light goes off then it'll do the same thing w/o making a mess. It's just a matter of getting oil pressure up before starting.</TD></TR></TABLE>
ooo **** i never fill it...expletive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by character »</TD></TR><TR><TD CLASS="quote">i fill it the filter and do it carefully so it doesnt spill. you suck</TD></TR></TABLE>
yeah, I must suck because the stock fuel strainer will blow my motor on a walboro
does it really matter? its not like you're going to have any oil inside the filter if you let it the car sit for a while.. half a day is probably enough to have oil filter completely dry.. so what do you do then? remove it and refill with oil everytime before startup?
i dont have a honda but i always put in my oil filter in dry. For 94k miles i have. 89k was with stock turbo and i pused 22psi ever day and the turbo ran great. I dont see the point. But that me
I know it's a good practice to fill the filter, but I never do. I checked my gauge after my last oil change - it only took about 2.5 seconds to build pressure. That doesn't seem like a problem since the engine is only idling for those two seconds. Plus there is always residual oil sitting on the bearings from the last run, so it's not like the engine is really going to "starve".
Having said that, my roommate *swears* that he spun a bearing on his old camero by not filling the filter first... I don't believe him though. I think he built a crappy motor.
