what do I trust?
Old Apr 29, 2003 | 10:52 AM
94dxt's Avatar
Default what do I trust?
when I have my 7k rpm rev limiter chip in my btm, it engages @ about 6700rpm. What is wrong the Autometer tach or the msd [don't have factory tach (dx)]?
Old Apr 29, 2003 | 11:01 AM
bryan305's Avatar
Default Re: what do I trust? (94dxt)
isn't the factory redline ~6700?
Old Apr 29, 2003 | 11:10 AM
sweet's Avatar
Default Re: what do I trust? (bryan305)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryan305 &raquo;</TD></TR><TR><TD CLASS="quote">isn't the factory redline ~6700?</TD></TR></TABLE>
yes i believe for the D15B7 DX motor it's about 6,600-6,700 rpm cutoff.
he's running the D16Z6 EX/SI motor, so i'm assuming he's also using the P28 ECU that goes along with that. if he is then it should be more like 7,200 rpm if i remember correctly. aftermarket tachs are normally off a bit from experiences i've had, so i would go by what the ignition reads. though both the tach and the ignition box read off of the same signal normally, the tach needle is often times off a bit.
Old Apr 29, 2003 | 11:14 AM
94dxt's Avatar
Default Re: what do I trust? (sweet)
7200 rpm is the fuel cutout on the ex ecu (which I am using) and my tach is accurate w/that so I guess it's my msd chip, that sucks
Old Apr 29, 2003 | 11:24 AM
black92si's Avatar
i've had msd chips go bad before. try replacing the chip first since that is the cheapest thing you could do.
Old Apr 29, 2003 | 12:25 PM
94dxt's Avatar
Default Re: what do I trust? (black92si)
I have two 7000 chips both activate at the same time
f-it3
Jan 30, 2006 01:29 PM
SPOOLINmatt
Oct 20, 2005 08:37 PM
B16Civic93
Nov 27, 2004 07:04 AM
integra-modder
Oct 27, 2002 01:44 AM
