What did I break this time?
Old May 12, 2013 | 02:22 PM
StevieR's Avatar
Default What did I break this time?
Broke it again. Sounding like bottom end, but I cant be sure till I do a compression and leakdown test. You can definitely hear a squeak though. Any guesses before I pull it apart?
Old May 12, 2013 | 04:46 PM
Gunmetal_B20_Hatch's Avatar
Default Re: What did I break this time?
Broke a rod + hole in the block.
Been there, done that.
Old May 12, 2013 | 08:42 PM
StevieR's Avatar
Lol, I'm pretty sure the rod is okay. You'd hear a bit more clanging I'm pretty sure. This was a Laskey built bottom end too. So lets hope. I cracked my first block and this has many of the same symptoms. I've "been there done that" too, but I question how benson sleeves would let go at 25psi.
Old May 13, 2013 | 08:33 AM
I just sounds like it in the video... is it open DP?
Old May 13, 2013 | 10:21 AM
Balor_Gr's Avatar
Timing ok?
Maybe belt jumped a tooth or sth?
Old May 13, 2013 | 11:48 AM
StevieR's Avatar
Yeah open dump. I checked tdc for a skipped belt and everything checked out
Old May 13, 2013 | 11:52 AM
sanman000719's Avatar
yah sounds like timing is off or you on what 3 holes only
Old May 13, 2013 | 12:35 PM
StevieR's Avatar
My guess is piston is a big gaping hole, ring is broken, or sleeve has a huge crack.
Old May 13, 2013 | 02:29 PM
B and B's Avatar
Loved
Community Favorite
How much was that? Ouch.
sucks man, hope it's something non-catastrophic.
Old May 13, 2013 | 02:47 PM
StevieR's Avatar
All in around $5k after shipping and such.
Old May 13, 2013 | 05:12 PM
StevieR's Avatar
Bent a valve. Exhaust valve
Old May 13, 2013 | 05:45 PM
Muckman's Avatar
Moderator in Chief
Stock valve springs? How much boost/power? Did you over rev or over boost?
Old May 13, 2013 | 05:51 PM
StevieR's Avatar
Stock yeah. I have a fully ported head with S2 Pro Valvetrain sitting at home. Just hadn't put it in. Rev 8k@25psi. Probably just it's time to drop. I was actually impressed with how long this lasted. Glad it wasn't catastrophic.
Old May 13, 2013 | 08:27 PM
StevieR's Avatar
Here she is!
Old May 13, 2013 | 08:32 PM
familysedan2's Avatar
Nothing a quick valve lap can't fix eh
On a serious not, Hope all turns out good man..how does the bottom end look?
Old May 13, 2013 | 08:56 PM
StevieR's Avatar
Bottom End got away good. Very very minimal. It didn't completely drop. When it bent, it was bent in place high enough for the piston to never come in contact again. Thankfully I have a whole new, better top end waiting! I have a feeling this could have been some valve floating. After all, the head was bone stock.
Old May 13, 2013 | 09:12 PM
StevieR's Avatar
oh, and to the guy asking me power, I kinda read over that. Last year I dyno'd at 391.9 @6600 rpm due to ignition issues.
Old May 14, 2013 | 03:39 AM
Balor_Gr's Avatar
Its looks Someone above showed mercy to your 5000$ bottom end
Old May 14, 2013 | 03:44 AM
rich7777's Avatar
Here she is!
Hammer + vice = fix
Old May 14, 2013 | 04:22 AM
Muckman's Avatar
Moderator in Chief
At that boost level you need upgraded valve springs. Your valves were def floating.
Old May 14, 2013 | 04:58 AM
StevieR's Avatar
Yeah I have full S2 Pro Series Valvetrain waiting along with a ported head. I didn't put it on because I wasn't planning on re tuning this year.
Old May 14, 2013 | 09:16 AM
Schister66's Avatar
Man U FTW
Glad to see it wasn't major
Originally Posted by rich7777
Hammer + vice = fix
Haha...the Clarkson fix.
Old May 14, 2013 | 09:23 AM
TheShodan's Avatar
Moderator
Hammer + vice = fix
by the time he bends it on the vice, the metal's structural integrity is already compromised. Like a piece of small metal, once you've bent it back once, its not nearly as strong originally. Keep bending it back and forth and you'll eventually snap it.
new valve(s)..
Old May 14, 2013 | 09:26 AM
StevieR's Avatar
new valve(s)..
I hope they were only kidding... I'd be surprised if anybody actually thought that would be fixable. I might buy a laskey built top end to match the bottom instead of my S2 head.
Old May 14, 2013 | 09:34 AM
damm thats pretty bent up any contact with the piston
