What is a "bar of boost"???
Old May 27, 2005 | 06:53 PM
{StatuS ChecK}'s Avatar
Default What is a "bar of boost"???
My friend has a WRX and bought and installed a Subaru Boost gauge.
So does some one know how to translate "bars" of boost.
Like .5 bar is ???? PSI
1 bar is ???? Psi
1.5 bar is???? PSI.
thank yall.
Old May 27, 2005 | 06:57 PM
sharkcohen's Avatar
Default Re: What is a "bar of boost"??? ({StatuS ChecK})
1 bar = 14.7 psi
Old May 27, 2005 | 07:06 PM
93turbo16's Avatar
barrometric pressure is 14.7 psi, so, if you boost 1 bar, you are boosting 14.7.. and you do the math for the rest.
Old May 27, 2005 | 07:53 PM
Tad's Avatar
Tad
Default Re: What is a "bar of boost"??? (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">1 bar = 14.7 psi</TD></TR></TABLE>
Old May 27, 2005 | 07:57 PM
Bailhatch's Avatar
Default Re: What is a "bar of boost"??? (Tad)
1 atmosphere = 14.7 psi
1 bar = 14.5 psi
Old May 27, 2005 | 08:07 PM
ginoboy1978's Avatar
Default Re: What is a "bar of boost"??? (Bailhatch)
Bar / PSI
.25 / 3.63
.40 / 5.80
.50 / 7.25
.60 / 8.70
.70 / 10.15
.80 / 11.60
.90 / 13.05
1.00 / 14.50
There you go.
DAN
Old May 27, 2005 | 08:16 PM
sharkcohen's Avatar
Default Re: What is a "bar of boost"??? (ginoboy1978)
Yah, I should have checked my graphing calculator rather than the first page I found on google. 1 bar = 14.503773773 psi
Old May 28, 2005 | 01:01 AM
Thanks alot you guys. My friend searched Google, but was unsuccessfull.
Peace.
Old May 30, 2005 | 08:30 AM
ek_turtle's Avatar
1 bar of boost is 14.7 psi, rounded off 15 psi with that said this is the reason people with turbocharged hondas need to have 3bar map sensors to exceed 30psi. get it 2 15+15=30, 30+=3bar.
Old May 30, 2005 | 08:33 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: What is a "bar of boost"??? (b20da9)
not true... a 3 bar reads 1 bar of vacuum and only 2 of positive manifold pressure, so you could almost get 40 psi, almost but not quite
Old May 30, 2005 | 08:44 AM
DragSource's Avatar
BAR = 14.5 PSI @ Seal Level
In google, type:
"xx psi in bar" where xx is the amount of boost you are running. It will tell you the conversion to BAR @ sea level.
Old May 30, 2005 | 08:45 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (DragSource)
and what if i live 1100ft above sea level...
Old May 30, 2005 | 09:02 AM
DragSource's Avatar
Default Re: (wantboost)
The amount of Boost that BAR is equal to is going to be less for you.
I'll try to find the formula for that, in the mean time- here's a good read on this topic.
http://www.chevyhiperformance....7678/
Old May 30, 2005 | 09:05 AM
DragSource's Avatar
For every 1,000 feet in elevation, 1 BAR = approx .5 psi less.
So 1 BAR for you is just a smidge under 14 PSI. . . prob 13.9xx PSI
Old May 30, 2005 | 12:13 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20da9 &raquo;</TD></TR><TR><TD CLASS="quote">1 bar of boost is 14.7 psi, </TD></TR></TABLE>
nope, one atmosphere is 14.7. One bar is 14.5psi.
Old Sep 10, 2005 | 12:45 PM
TurboTeG4's Avatar
What is 14.7(1Bar)to kg/cm2?
Is it 1 bar=1kg/cm2?
Old Sep 10, 2005 | 12:49 PM
2point2's Avatar
Default Re: What is a "bar of boost"??? (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">What is 14.7(1Bar)to kg/cm2?</TD></TR></TABLE>
http://www.onlineconversion.com &lt;-- great site.
Old Sep 10, 2005 | 12:50 PM
turboEGhatch's Avatar
Are you that lazy, seriously?
1 bar to kg/cm^2
Into google. First result shows that you multiply pressure in bar by 1.02 to get pressure in kg/cm^2. How have you survived 28 years of life if you can't figure that out?
Old Sep 10, 2005 | 12:56 PM
TurboTeG4's Avatar
Default Re: What is a "bar of boost"??? (turboEGhatch)
Yeah I did that guys, im not that lazy, but just making sure I had the conversion right because of multiple kilogram options even though common sense tells me cm squared
Old Sep 10, 2005 | 03:05 PM
Merines's Avatar
http://www.digitaldutch.com/unitconverter/
End of all your conversion worries.
Old Sep 10, 2005 | 03:43 PM
Axle's Avatar
Whether in BAR or atm, you have to remember that it's all really a measure of pressure for which the SI unit is Pascals (Pa). Pa = 1 N/m^2.
1 atmosphere (atm) is 101,325 Pa but to simplify the mathematical conversions, they came up with BAR which is equivalent to an even 100,000 Pa.
Old Sep 10, 2005 | 05:05 PM
5thgen's Avatar
Default Re: (Axle)
like some say
1 bar = 1.0197kg/cm^2 = 14.503psi
Old Sep 10, 2005 | 06:34 PM
turbo_ef9's Avatar
Default Re: (5thgen)
hehe.. its funny reading this stuff.. all you folks arguing over how much boost a bar is.. here guys.. relax and this is on me oh.. i run a bar of boost on my car its fun..
Old Sep 10, 2005 | 07:06 PM
GetawayInMoscow's Avatar
Default Re: (eli_vang)
14.5 psi
http://www.google.com/search?hl=en&q=bar+to+psi
ensracer
Jul 16, 2006 10:09 AM
CarAudioPro
Dec 31, 2005 11:10 AM
Civiclx
Apr 12, 2004 07:19 AM
Bizarre
Sep 19, 2003 04:13 PM
dabrown
May 22, 2003 07:28 AM
