went to the dyno tonight....=(
Old Aug 22, 2003 | 11:18 PM
madman604's Avatar
Default went to the dyno tonight....=(
pulled a most unimpressive 188.1whp @ 10psi
WTF?
needless to say i'm pissed
Old Aug 22, 2003 | 11:33 PM
t616
Guest
Posts: n/a
Default Re: went to the dyno tonight....=( (Turbo E)
looks like its time for a compression/leakdown test.
Old Aug 22, 2003 | 11:39 PM
LiLOtaku's Avatar
OUch!
something's not right.
Old Aug 22, 2003 | 11:40 PM
psileepR's Avatar
New User
give us more info.. like dyno and a/f graphs... anything wierd happen while on the dyno?
whats your settings? base timing? etc
Old Aug 22, 2003 | 11:42 PM
accordexchange's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">pulled a most unimpressive 188.1whp @ 10psi
WTF?
needless to say i'm pissed</TD></TR></TABLE>
something is not right... i am making 215 whp @ 10 psi on my 94 accord ex auto...
Old Aug 22, 2003 | 11:43 PM
Boost2NA's Avatar
Default Re: went to the dyno tonight....=( (psileepR)
what type of dyno was it?
Old Aug 23, 2003 | 12:05 AM
accordfreak's Avatar
WTF?
i feel you man.. i was extremely pissed at my numbers... hopefully you'll resolve your problems.
Old Aug 23, 2003 | 12:42 AM
Timmay's Avatar
something is got to be wrong, i dynoed a stock 98 gsr with greddy intercooled kit on 7-8 psi put 202 WHP
Old Aug 23, 2003 | 02:07 AM
nigel's Avatar
I think I figured it out.. GREDDY TURBO KIT on a b series. what I have noticed is those greddy kits are only good on single cams.
Old Aug 23, 2003 | 05:33 AM
prophet's Avatar
...i made 248whp on 5.5psi.....i suggest you get your engine checked out.
Old Aug 23, 2003 | 05:38 AM
gitwidit's Avatar
Default Re: went to the dyno tonight....=( (prophet)
was it just fallin on it's face or what?
Old Aug 23, 2003 | 05:49 AM
Burke's Avatar
Banned
Default Re: went to the dyno tonight....=( (GITWIDIT)
when i had my jdm b18c NA it dynoed 165 whp. i hope its not the comp. good luck resolving it!
Old Aug 23, 2003 | 09:28 AM
hypa's Avatar
Elton, let me have some time with it and we can make up the power you're losing. I know it's a tuning issue because we have no one who actually knows how to tune in our area!
FYI, it's a dyno dynamics unit.
I ran a 138/133lbs on my stock (cam gears, fpr, timing) b20, and another car we tuned ran a 163/128lbs on a hondata (hondata customer service sucks! ) tweaked GSR powered civic. I know the dyno is good because we g-tech'd to confirm.
Old Aug 23, 2003 | 10:46 AM
nigel's Avatar
Default Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote"> I know the dyno is good because we g-tech'd to confirm.</TD></TR></TABLE>
I ran a 12.9 on the gtech with a stock b16 naturally asipred.
Old Aug 23, 2003 | 08:00 PM
madman604's Avatar
Default Re: (hypa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa &raquo;</TD></TR><TR><TD CLASS="quote">Elton, let me have some time with it and we can make up the power you're losing. I know it's a tuning issue because we have no one who actually knows how to tune in our area!
I ran a 138/133lbs on my stock (cam gears, fpr, timing) b20, and another car we tuned ran a 163/128lbs on a hondata (hondata customer service sucks! ) tweaked GSR powered civic. I know the dyno is good because we g-tech'd to confirm.</TD></TR></TABLE>
so hypa pm me with a ball park figure for some dyno tuning. froom star to finish. i need this **** worked out. BTW the car was running super rich for some reason. my compression is over 200 across the board so I know the cylinders are in fair shape.
I was hoping to hit at LEAST 250 hp
Old Aug 23, 2003 | 08:07 PM
danl's Avatar
Banned
Default Re: (Turbo E)
Looking at your trap speed, youre making power. The dyno is just "calibrated" differently. Don't worry, I made 140 hp one day, and the next day I pulled 99 mph traps at the track in a 2900 lbs car.
Old Aug 23, 2003 | 08:16 PM
madman604's Avatar
Default Re: (danl)
Old Aug 23, 2003 | 09:01 PM
FredoSP's Avatar
do a compression test, i have a feeling it will tell you a lot.
Old Aug 23, 2003 | 09:11 PM
soulless1's Avatar
Default Re: went to the dyno tonight....=( (FredoSP)
What should the compression be about
Old Aug 23, 2003 | 09:15 PM
SiRkid's Avatar
stock compression.
around 220 is good
thats what i have across the board
Old Aug 23, 2003 | 10:48 PM
DLOTYPER's Avatar
220 sounds high as hell!!! anybody agree?
Old Aug 23, 2003 | 10:53 PM
Drew Peacock's Avatar
Default Re: went to the dyno tonight....=( (SiRkid)
Looking at that dyno you started to detonate at the top end....... Go some where else for tuning
Old Aug 30, 2003 | 10:13 AM
DigitalFusion's Avatar
Default Re: (DLOTYPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLOTYPER &raquo;</TD></TR><TR><TD CLASS="quote">220 sounds high as hell!!! anybody agree?</TD></TR></TABLE>
Yeah, altho compression gauges can vary. My B16A3 is around 180-185 on my gauge.
Old Aug 30, 2003 | 10:21 AM
Ado's Avatar
Ado
188.1 OMG man, you gotta sort out some problems, I thought you would be easy 250whp or more. Im sure Hypa can help ya out he seems to know everything, and is prob one of the only people in the Van area that I would let tweak with my car....Once you get everything worked out let me know what numbers you are pulling...good luck man
Old Aug 30, 2003 | 11:32 AM
Retired's Avatar
WEST COAST
WTF?
I would get another tuner If you in So Cal Hit up Bubba (TrackMasters) he can tune a mean hondata. Also do you have alot of blow-by? If so,the motor will still have compression but the piston might be cranked between the first and the second ring. Also Boost owns casted pistons over time I recommend going with a forged set. Good Luck, I hope its just the tuner.
