Welding dis-similar materials
Old Mar 16, 2003 | 02:33 PM
Greaser's Avatar
Default Welding dis-similar materials
I just bought a Miller 135 and got the standard .030 wire for mild steel. I have to weld a Stainless flange to Schedule 40 weldels.
Will the wire i'm using and the C02/AG flux work for welding stainless to mild steel?
Old Mar 16, 2003 | 05:57 PM
420aNT's Avatar
Default Re: Welding dis-similar materials (Greaser)
You can use that wire but, I suggest Tig for welding dissimilar materials for best results though
Old Mar 16, 2003 | 07:46 PM
SuperT's Avatar
You should not use mild steel wire to weld stainless.
Use 309 wire to weld stainless to mild steel. You can also get away with using 308 wire but 309 is best when welding mild to stainless.
You can buy them in 2 pounds spools for a reasonable cost.(about 14.00 last I recall)
You can MIG weld stainless to mild very nicely and successfully, but it does take practice....
Hope that helps!
Dave
Old Mar 17, 2003 | 09:23 AM
Greaser's Avatar
Default Re: Welding dis-similar materials (SuperT)
Thanks, i dont feel like getting another tank of sheilding gas or spool wire for one weld. so i'll drop the collector off at a local fab shop for a 20$ welding charge. should only take them 10mins.
Man this stuff is fun......collector is done, just need to get welded to the stainless T4 divided inlet.
Old Mar 17, 2003 | 09:28 AM
legendboy's Avatar
You are absoloutly fine welding stainless with non stainless wire. If you weld it properly it shouldn't crack any more than mild steel. The only thing is that it will rust. But it would rust anyways if you welded with stainless wire and you don't pasify it after. And a mig weld can be just as strong as a tig weld, maybe even stronger.
[Modified by legendboy, 11:29 AM 3/17/2003]
Old Mar 17, 2003 | 09:46 AM
Greaser's Avatar
Default Re: Welding dis-similar materials (legendboy)
Have you done it before? I could care less how it looks or if it rusts. My requirement is strength and resistance to cracking or just falling the fack off
I did a small spot weld and then cut into it and it looked like a good weld. It looked just as if i cut into the metal that had no weld in it.
Old Mar 17, 2003 | 09:49 AM
Full-Race Javier's Avatar
use 309
either that or tack it then have someone tig it.
Old Mar 17, 2003 | 09:55 AM
Smashback's Avatar
I've done it plenty ... I always use mild wire when welding stainless to mild and never had any probs...my cat is stainless, my muffler is stainless, and all my piping is mild. running about 1 year and no probs whatsoever.
Old Mar 17, 2003 | 10:25 AM
Greaser's Avatar
Default Re: Welding dis-similar materials (javierb14)
you know that an exhaust manifold encounters extra heat and weight being the extra stress that your cat and muffler dont really go through.
Old Mar 17, 2003 | 11:09 AM
legendboy's Avatar
it doesn't really matter, your using schedule 40 pipe which wont crack itself, so as long as you weld it properly it will be fine.
Sirfallsalot243
Welding / Fabrication
10
May 29, 2007 08:04 PM
twilightprotege
May 22, 2006 04:52 PM
turbotime
Apr 15, 2006 11:43 AM
fastcivicboy
Feb 19, 2005 01:02 PM
Bantam
Nov 26, 2004 08:56 AM
