wd40 ???????
Old Jan 8, 2007 | 07:50 PM
crvtkllr's Avatar
Default wd40 ???????
i have a built b16T block with no car to put it in yet. the cylinders have been sprayed with wd40 is it ok to clean the block the run it???
the motor is already built it just doesnt have a head on it..
thanxs guys
Old Jan 8, 2007 | 07:57 PM
ccivic's Avatar
Default Re: wd40 ??????? (crvtkllr)
why wouldn't it be? as long as it was assembled properly, and has been properly sheltered and lubricated while being stored.
Old Jan 8, 2007 | 08:06 PM
ccivic's Avatar
Default Re: wd40 ??????? (.EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Coat the cyl. walls with fresh oil before the initial start-up. WD40 is too thin.</TD></TR></TABLE>
I disagree. I was actually recommended by many well known engine builders to use WD40 rather than engine oil in assembly. The only oil I used was on bolts, and I also put a light coating on the piston skirts before I put them into each cylinder.
The reasoning behind this is to seat the rings quicker-- less lubrication, faster seating. I know this type of thinking would normally be berserk, but oil will see the cylinder walls in no time anyhow.
Old Jan 8, 2007 | 09:55 PM
Joseph Davis's Avatar
Default Re: wd40 ??????? (ccivic)
WD40 is kerosene based, and it evaporates. It is not an oil in the lubricating sense.
Old Jan 9, 2007 | 09:24 AM
crvtkllr's Avatar
the motor was well stored and put together perfect because i built it i had taken the head off because of a blown valve seal. so i have been spraying the cylinder walls and head with wd40 to keep the rust off. but i am going to definetly clean and lubricate the motor with a lite coat of engine oil before assembly again.
Old Jan 9, 2007 | 10:35 AM
White Smoke's Avatar
i my honda
Global Mod
Yea its OK to run. You don't need any oil on the walls before you start it. As stated the WD40 is only to keep the rust off till you assemble it, that is all.
Old Jan 9, 2007 | 12:51 PM
i my honda
Global Mod
It takes a new motor as much as 30 seconds of priming to build oil pressure. That's not what I'd consider "no time."</TD></TR></TABLE>
OMG you are so smart, cant put anything past you. Tell me Mr. know-it-all, how is it that oil gets onto you cylinder walls when the engine has built oil pressure? Guess what, it doesn't! There is absolutely NO NEED for oil on the cylinder walls, EVER! Not when the car has oil pressure and not when the car has -0- pressure. The only thing you want in there is air, and hopefully some atomized gas. Adding oil will only slow down the ring seating process with CAN LEAD to improperly seated rings which will result in poor leakdown.
Since you clearly don't understand the purpose of the WD40, ITS TO KEEP THE RUST OFF! That is the ONLY reason its even there. The cylinder requires no lubrication... Unlike your girl from what I'm told.
Old Jan 9, 2007 | 04:25 PM
speedworks's Avatar
Default Re: wd40 ??????? (White Smoke)
i also use wd-40. i spray the rings and cylinder walls before installing. rings seat quick this way. i have never had a problem.
Old Jan 9, 2007 | 04:33 PM
DRAGLS's Avatar
Default Re: wd40 ??????? (speedworks)
Use marvel mystery oil on your cylinder walls.
Old Jan 9, 2007 | 04:53 PM
turboteener's Avatar
Banned
Use WD40 or a light coat of transmission fluid. Works fine.
Old Jan 9, 2007 | 04:59 PM
DaveF's Avatar
Default Re: (turboteener)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener &raquo;</TD></TR><TR><TD CLASS="quote">Use WD40 or a light coat of transmission fluid. Works fine.</TD></TR></TABLE>
atf thats what i use. but when "storing" a block i will apply wd-40 with generosity
Old Jan 9, 2007 | 05:11 PM
tony1's Avatar
Whitesmoke, give Enzo a break, he's in that 99%
Old Jan 9, 2007 | 05:12 PM
93supercoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">r:
Since you clearly don't understand the purpose of the WD40, ITS TO KEEP THE RUST OFF! That is the ONLY reason its even there. The cylinder requires no lubrication... Unlike your girl from what I'm told. </TD></TR></TABLE>
That might be the GAYEST thing ever posted on HT, b/c she carries lube in her purse
Thats terrible.
Old Jan 9, 2007 | 07:12 PM
Muckman's Avatar
Moderator in Chief
Default Re: wd40 ??????? (tony1)
lol tony
I coat my cylinder walls with epoxy. It really helps the rings seal.
Old Jan 9, 2007 | 07:24 PM
IndySporty's Avatar
No I use Super Glue man! Haven't you ever seen american pie?? Great lubrication for that critical start-up, then unbeatable seating for the rings!!
Old Jan 9, 2007 | 11:18 PM
Quality!
This thread is Joey approved.
Old Jan 10, 2007 | 03:25 AM
MiraiZ's Avatar
Default Re: wd40 ??????? (Joseph Davis)
WD40 is not a lubricant...its a water displacing agent
Old Jan 10, 2007 | 03:31 AM
Bailhatch's Avatar
Default Re: wd40 ??????? (MiraiZ)
WHHEEEEEEEeeeeeeeeeeee
Old Jan 10, 2007 | 03:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jean Luc Picard &raquo;</TD></TR><TR><TD CLASS="quote">WD40 is not a lubricant...its a water displacing agent</TD></TR></TABLE>
Is that the technical term for kerosene, Captain?
I didn't do that as well as .EnzoSpeed, did I? Anyone care to critique my form?
Old Jan 10, 2007 | 04:19 AM
TheWickedOne's Avatar
I just Duck Sauce, After startup, my exhaust smells schweet...
Old Jan 10, 2007 | 08:08 AM
N20civicB18's Avatar
Default Re: (TheWickedOne)
I use wd40 on the engine walls I build... I find if I use motor oil or lube it takes a long time for the rings to seat. WD40
Old Jan 10, 2007 | 11:00 AM
HiProfile's Avatar
You are definately confusing dumping oil into the combustion chamber with lubricationg the cylinder walls. Ever try rubbing bare aluminum on bare iron at a 875 FEET PER MINUTE (speed of a honda piston at 1500rpm)? Ever wonder why they call the lowest rings oil control rings? Ever expose a thin film of a petrolium-based product to 1500 degrees? It will burn off the compression rings before you can say "Whitesmoke is a degenerate retard" - try it.
But back to the topic of which type of oil to use - I wouldn't use wd40, as kerosene is good as a degrease despite coming from crude oil; its much like gasoline in that sense. Auto trans fluid is what a lot of people I know use - it prevents rust, has a very tough film, and won't wash the oil off the cylinders once it starts flying up there. The best thing it was designed as a lubricant. Wd40's uses include cleaning dried bugs from bumpers and killing small animals. As my motor's bores are devoid of dried bugs before assembling, I'd rather have a longer breakin time than scuffed pistons. But then again, as long as it doesn't develpe more than a handful of full-length scratches that can be felt with your fingernail, your okay, right?
Otherwise use what marine people use for storing motors - fogging oil. You spray it into though the plug hole, rotate it a bit, and your golden for a few months.
Old Jan 11, 2007 | 03:18 PM
DRAGLS's Avatar
Default Re: wd40 ??????? (HiProfile)
Just use the marvel oil.
Old Jan 11, 2007 | 05:03 PM
pheurton-skeurto's Avatar
...Jean Luc Picard
Old Jan 11, 2007 | 05:54 PM
ProjectDarkBlack's Avatar
Default Re: wd40 ??????? (pheurton-skeurto)
I dont even run oil, I run straight W-D, its expensive for 4 quarts, but it works better because my engine doesn't need lube.
