wastegate. vacuum or pressure?
Old Jan 12, 2003 | 05:14 PM
shortyz's Avatar
Default wastegate. vacuum or pressure?
ok im confused here. now the wastegate is fully open at idle because of vacuum. but when the turbo hits 5psi is it vacuum or pressure in the manifold that pulls/pushes the wastegate open??
now if i have a vacuum pump. if i pump it up to 5psi vacuum the wastegate should open? 5psi vacuum = 5psi boost?
i am so confused.
[Modified by shortyz, 6:28 PM 1/12/2003]
Old Jan 12, 2003 | 05:52 PM
integra_gsr98's Avatar
Default Re: wastegate. vacuum or pressure? (shortyz)
When you are dealing with wastegates you are dealing with postive pressure in the lines. If the wastegate spring is at a stiffness where 5 psi (pounds per square inch.. pressure) can compress the spring, the WG diaphram will open and let excess exhaust out in order to help control boost levels.
Vacuum is not measured in PSI, as it is an absence of pressure in the lines. You could attach a vacuum pump to the system and you would be unable to get the wastegate to open. However, attach an air compressor to the system and you will be able to open the wastegate as you are introducing postive pressure into the system.
Old Jan 12, 2003 | 06:14 PM
shortyz's Avatar
Default Re: wastegate. vacuum or pressure? (integra_gsr98)
uhm this one i got when i hook it to vacuum at idle it pops open.
Old Jan 12, 2003 | 06:33 PM
racerxadam's Avatar
are there two ports on the wastegate? it should be held shut with spring pressure at idle and open when the air pressure from a boost source reaches the pressure that the wastegate is designed to open at.
Old Jan 12, 2003 | 06:50 PM
shortyz's Avatar
Default Re: wastegate. vacuum or pressure? (racerxadam)
theres 2. ones threaded. whats what.
Old Feb 3, 2009 | 04:21 PM
jdmsinglecamdelsol's Avatar
lol wow i have a built sohc and a built ls and im working on a dd sohz zc on 8 psi and cant remember how to put the valve seat in wow lol lil help or il take my other one off and look at it
Old Feb 3, 2009 | 04:22 PM
^^^^valve seat in the wastegate
Old Feb 3, 2009 | 04:34 PM
blinx9900's Avatar
WG is supposed to see pressure, i believe i have seen TIAL themselves post stating that if you hook it up to vacuum it may still work but could tear the diaphragm.
Kid-jdm-teggy
Mar 19, 2014 03:02 PM
lsturbo*
Aug 17, 2009 12:39 PM
2muchPSI
Nov 22, 2003 02:34 PM
_Endless_
Jan 8, 2003 11:24 PM
