Walbro 255 Fuel Pump
Old Nov 12, 2006 | 08:44 PM
harley06's Avatar
Default Walbro 255 Fuel Pump
whats the difference between a walbro 255 lph and walbro 255 lph HP.. which one should i use for a turbo d16z6?
http://shopping.lightningmotor....html
on that website it sells those 2 different types, but the 255lph HP is 10 bucks more
Old Nov 12, 2006 | 09:07 PM
borat's Avatar
Default Re: Walbro 255 Fuel Pump (harley06)
HP = High Pressure
"These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour."
From here: http://www.nolimitmotorsport.com/walbro/
Old Nov 13, 2006 | 01:20 AM
88_DX's Avatar
Default Re: Walbro 255 Fuel Pump (borat)
HP FTW
boosted_D
May 12, 2012 07:20 AM
86si
Jan 31, 2005 07:18 PM
89civic1.8T
Dec 3, 2004 01:50 PM
DubyaAye
Nov 12, 2002 10:14 AM
Tuan
May 23, 2002 05:45 PM
