walboro fuel pump install, help
Old Dec 27, 2004 | 09:10 PM
sneakypete's Avatar
Default walboro fuel pump install, help
I'm installing a new walboro fuel pump and I was wondering if your suppose to use a zip tie to hold the body of the fuel pump to the metal housing? The stock pump slides into the bottom of the metal housing but the walboro doesn't fit as good as the stock pump.
Old Dec 27, 2004 | 09:35 PM
drive4show's Avatar
Default Re: walboro fuel pump install, help (sneakypete)
Just installed a Walbro fuel pump a few weeks ago. When you take the old one apart, there is a brown plastic piece (IIRC) at the base of the old pump that needs to be moved over to the new fuel pump. This brown piece sits between the fuel pump (main metal cylinder thing) and the filter screen bag (the white mesh filter bag).
At first, I didn't know to move the brown piece over, and found the new fuel pump sat kinda loose in the bracket. After I moved the brown piece over, the new fuel pump was snug as a bug.
If you have the pieces in front of you, you'll know what I'm referring to.....
Old Dec 27, 2004 | 10:05 PM
CivicEJ1's Avatar
I just installed my walboro 255lph fuel pump last night and god damn those rusted bolts are a bitch.. with 9 degree's temps when I was doing it too..had to keep the doors open for ventilation
Old Dec 27, 2004 | 10:12 PM
DRIVENRacing's Avatar
very easy instal... u dont need zip ties, just bend the bootom u bracket down a tad till the rubber piece on the bottom of the fp slides in... gl
Obama
Texas -OK -LA (Sales)
Oct 28, 2010 12:18 PM
prelude994e
Sep 13, 2004 11:23 AM
VspecSiR
May 17, 2004 04:37 AM
