vortech blow off valve question
Old Jun 12, 2005 | 03:38 PM
sproket13's Avatar
Default vortech blow off valve question
just installed a vortech on my 99 si. when ever im cruising, keeping speed, its just blowing off...rediculously loud..we have tightened it, loosened it...yet still the same problem, i knew it would be pushing air...but not like this, its like the loudest whistle ive ever herd...anyone else have the kit and know how to fix this?!? it cant be normal!
Old Jun 12, 2005 | 04:54 PM
Endoe's Avatar
Default Re: vortech blow off valve question (sproket13)
vortechBOV is always pushing out air....i would say try adjusting the pressure or check in the BOV maybe the valve got stuck on the rubber sealer?????
Old Jun 12, 2005 | 04:58 PM
Bailhatch's Avatar
Default Re: vortech blow off valve question (Endoe)
I put a softer spring in mine to keep it from surging. It never whistled but im sure that would fix it for you.
Old Jun 12, 2005 | 05:18 PM
sproket13's Avatar
Default Re: vortech blow off valve question (Bailhatch)
a softer spring!!!! we can push it in w/ one finger, not even that hard...i think the valve is bad, i did buy it used..but low miles, but god knows how the person before me used it. we hooked up a greddy BOV and it worked fine...so maybe. but i herd the vortech is suppose to do that, but why the hell is it whisling SOOOO loud! ive herd vortech's b4, its nothing like this..lol
Old Jun 12, 2005 | 05:55 PM
Bailhatch's Avatar
huh, the spring that came in mine was really stiff (from a revhard kit) very hard to push in with your thumb. The one i put in feels about the same as a Turbo XS one. try a stiffer spring then. as long as it blows off clean with little to no surge run it.
Old Jun 13, 2005 | 02:43 PM
sproket13's Avatar
but those are BOV's that are designed for a turbo...do you think the vortech is any different?!?
Old Jun 13, 2005 | 03:20 PM
wantboost's Avatar
Who is Mr Robot?
the vortech supercharger itself whistles... and the supercharger will almost always be making boost, since it is driven by the motor and not by load.
thats why...
Old Jun 13, 2005 | 06:32 PM
sproket13's Avatar
Default Re: vortech blow off valve question (wantboost)
yah, well then i need to get a blow off valve that dosent WHISTLE like a train! it has to be broken, there is no way people drive aroudn with this
Old Jun 13, 2005 | 07:15 PM
wantboost's Avatar
Who is Mr Robot?
its not broken... thats how it sounds, you just dont like it, lol
Old Jun 14, 2005 | 01:09 PM
sproket13's Avatar
i loosened the **** out of it...sounds much better, no more whistling i guess we just had it too tight, and instead of WOOOSHING, it was whistling
B18C_EJ8
Jan 6, 2007 07:04 PM
TypeR II
May 13, 2005 05:58 PM
racingfan
Jan 30, 2005 12:41 PM
civiceg500
Jan 22, 2005 06:33 AM
Mr.DC2TurBo
Dec 19, 2002 07:52 PM
