victor X tb opening
Old Jan 31, 2005 | 07:31 PM
del slw's Avatar
Default victor X tb opening
ive asked many people, and looked all over. but i can't find anywhere what the MM size is for the throttle body on the b16/type R edlebrock Victor X IM.
JG sells 65mm, and 70mm TB's. so which does the manifold have?
-Robbie
Old Feb 3, 2005 | 12:43 PM
wacky96d16's Avatar
Default Re: victor X tb opening (del slw)
Get the 70 with a plate to fit the victor X then port match...
unless you want a smaller one.
To be direct. I don't know which one comes with it... but I would go large and port the opening to fit.
Old Feb 3, 2005 | 02:31 PM
msmotorsports's Avatar
JG IM's come with a standard 65mm TB opening.
Old Feb 3, 2005 | 07:03 PM
del slw's Avatar
Default Re: victor X tb opening (wacky96d16)
what's the point of the plate. and why is it needed?
Old Feb 4, 2005 | 04:52 AM
wacky96d16's Avatar
to match the mounting points. It's needed on the 70mm not sure if you'll need it if you go 65. I'll try to take a pic tonight so you can see how it mounts.
Old Feb 4, 2005 | 08:05 AM
Andre's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wacky96d16 &raquo;</TD></TR><TR><TD CLASS="quote">to match the mounting points. It's needed on the 70mm not sure if you'll need it if you go 65. I'll try to take a pic tonight so you can see how it mounts.</TD></TR></TABLE>
The 70mm BBK throttle body fits without a mounting plate on the VictorX and so does the STR.
Why get a Mustang throttle body with a plate?
Old Feb 4, 2005 | 08:24 AM
jDMJeRk's Avatar
Ive heard of people using the mustants tb too... My gfs dad tried to get me to do it but i had spaceballs rebuild mine istead
Old Feb 5, 2005 | 03:19 PM
del slw's Avatar
Default Re: (jDMJeRk)
i'm picking up a holley 68mm tonight. even trade for my black VAFC-II
Old Feb 7, 2005 | 12:58 AM
CTRbOy's Avatar
Default Re: (del slw)
the 70mm str fit fit flush wit the victor x on mine.
Old Feb 7, 2005 | 02:01 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: victor X tb opening (Andre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andre &raquo;</TD></TR><TR><TD CLASS="quote">
from what ive seen they are like 100 bucks cheaper than bbk/str etc..the plates also let u adapt the 75mm..
Old Feb 7, 2005 | 05:09 AM
Andre's Avatar
Default Re: victor X tb opening (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">
from what ive seen they are like 100 bucks cheaper than bbk/str etc..the plates also let u adapt the 75mm..</TD></TR></TABLE>
The BBK 70mm sells for $270 new on ebay. The BBK and STR accepts stock TPS and MAP sensors.
I don't think you want a 75mm TB on a street car.
You can but must not open up the VictorX with the BBK and STR.
Old Feb 7, 2005 | 10:09 AM
SYD's Avatar
SYD
i understand that 100% but the option works for some of us ..so i guess thats where u can make the decision..ive seen the MTB go for 180-200 new..most boost guys are not running map of the TB anyway and alot are running an ems thats compatible with just about any TPS or whatever..so i guess it is a good option to have for some.
my9thtry
Dec 11, 2012 08:35 AM
shahriar35
Mar 2, 2010 11:38 AM
Topdawgg
12
Jan 1, 2006 03:28 PM
eymnewdc4
Nov 22, 2005 04:30 PM
hybridb18
Sep 11, 2003 04:59 PM
