Victor X IM is in...idle problems
My manifold and hondata gasket is in and I definately felt an increase in power up top, but the problem now is that my idle is off. My idle use to be 750, but has now climbed to 1000...also when I let off the gas it would idle at 1500 for about 4-5 sec and then drop to 1000. I dont know whats causing the problem. Everything is plugged in except for the vtec black box? which has two hoses coming out of it that controls the butterflies. I'm assuming I did not need it anymore so I left it unplugged.
yeah....vacuum leak....
take some brake cleaner...spray it where the leaks COULD be...and when you hear your engine rev up from the brake cleaner...thats where you leak is....
[Modified by integra7, 9:56 PM 11/26/2002]
did you clean off all of the old gasket still stuck on the head before you installed the hondata one?
si_motor_spt
Nov 14, 2008 03:14 PM
DriveSlowHomie
Mar 29, 2005 10:08 PM
