VAFC: sensor settings anyone know what they are for
Old Apr 27, 2003 | 11:23 PM
RuthlessEF-9's Avatar
Default VAFC: sensor settings anyone know what they are for
instructions say to run it on 6in and 6out however when i hooked up my pressure sensor my idle came ruff and when i disconnected it, it went back to normal so what i tried was is reconnect the pressure sensor. and raise the "in" setting to 10 and left the out at 6 it idle perfect i just want to know if anyone else ran into any problems like mine and if you could help out
thanks in advance
Old Apr 28, 2003 | 05:10 AM
swlabhot's Avatar
Default Re: VAFC: sensor settings anyone know what they are for (D16z6turbs)
U should leave it @ 6 like the instructions says. Check you Cyl setting, it should be at 4, you might have it set at 6 at the moment....just a rough guess. Assuming u checked and double checked that ur AFC wiring is spot on.
jdmcivicferio
15
Jul 5, 2005 10:35 PM
flashmntbiker
Nov 12, 2004 08:43 AM
Revi
Jul 9, 2004 10:00 AM
Luserkid
30
Apr 8, 2004 11:24 AM
