vacuum manifold cap? plug?
Old Jun 20, 2005 | 11:31 AM
95BlkGSR's Avatar
Default vacuum manifold cap? plug?
i have a vaccum manifold with 5 nipples coming off...i only need 3, how do i plug the other 2, will there be to much pressure to plug them...
any1 got any ideas?
Old Jun 20, 2005 | 11:48 AM
RacerXI's Avatar
Default Re: vacuum manifold cap? plug? (95BlkGSR)
I picked mine up at ace hardware. It has the same size fittings as your barbed nipples, but it has a square plug. HTH.
Old Jun 20, 2005 | 02:03 PM
RyanEJ8's Avatar
It's not the best looking, but if you need a quick fix take a piece of rubber hose and shove it over the barbed fitting and then plug the end of the rubber hose with a spare bolt.
If you can remove the barbed fitting from the vacuum manifold you could possibly put a plug fitting in it's place.
Old Jun 20, 2005 | 07:14 PM
95BlkGSR's Avatar
Default Re: vacuum manifold cap? plug? (RyanCivic2000)
thats wat i was thinking about doing the bolt thing...or possible melting the end of a tube....w/ a soldering iron
Old Jun 20, 2005 | 07:29 PM
Wideopentuning's Avatar
Any 1/8" npt male plug should work. Summit sells nice chrome ones that are an allen head for like $5 for 4
Old Jun 20, 2005 | 08:04 PM
atli126's Avatar
Default Re: vacuum manifold cap? plug? (Wideopentuning)
what vacume mani are you using and where did you get it
thanks
bret
Old Jun 20, 2005 | 09:34 PM
Def's Avatar
Def
Default Re: vacuum manifold cap? plug? (atli126)
You can get rubber caps at places like Autozone/NAPA etc. Put a ziptie around them if you're paranoid about them coming off(but they usually don't when just put on there, even at 15 psi, lots of friction).
Old Jun 21, 2005 | 08:36 PM
95BlkGSR's Avatar
Default Re: vacuum manifold cap? plug? (Def)
a manifold made by a local shop
Old Jun 22, 2005 | 06:49 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95BlkGSR &raquo;</TD></TR><TR><TD CLASS="quote">a manifold made by a local shop
That looks like it's made out of the same McMaster Carr parts I used to custom make my vacuum manifold. Just take the barb fitting out and plug the hole 1/8" NPT male plug.
Old Jun 22, 2005 | 05:10 PM
Cee_mon's Avatar
Mcmaster carr.....with 1/2 cap on the end, and 1/8th on the front side with the rest.
Old Jun 23, 2005 | 09:53 PM
95BlkGSR's Avatar
Default Re: vacuum manifold cap? plug? (Cee_mon)
i screw a blot w/ glue on it into vacuum line and put it on...should work fine...i hope
Old Jun 23, 2005 | 11:12 PM
NuclearB18B's Avatar
maybe try looping it?
Old Jun 23, 2005 | 11:27 PM
Cloner's Avatar
Default Re: vacuum manifold cap? plug? (NuclearB18B)
I just plug up the holes with the 5min stick weld.Works great.
brokenojoke
22
Apr 23, 2012 03:33 AM
prox25
26
Oct 13, 2009 11:57 AM
blakacintegra
May 12, 2007 08:52 PM
djnikko
Jul 5, 2004 08:06 AM
LonelyDriver02
Nov 21, 2003 12:20 PM
