vaccum/boost changeover
Old Aug 20, 2007 | 04:47 PM
crawlin's Avatar
Default vaccum/boost changeover
i just finally got my car tuned with my turbo on, and after letting off after boost and hit the brakes my brake pedal is super hard and i really cant stop. it makes sense because you loose all vaccum in boost. but i was wandering is this common or not? i was thinking about making a vaccum box to have a secondary source of vaccum. any input would be great.
Old Nov 18, 2007 | 01:56 PM
logg_frogg's Avatar
Default Re: vaccum/boost changeover (crawlin)
They actually make vaccum pumps that go inline with your brake booster to help with this very problem!
I have seen a few links on here under brakes faq but don't have the time to link one right now >.< sry bro
Old Nov 18, 2007 | 05:14 PM
kyden's Avatar
your brake master shouldn't see boost anyway, so the issue here is do you have anything attached to that vacuum hose? maybe you are getting boost past the check valve and in the diaphragm?
Old Nov 18, 2007 | 05:26 PM
Schister66's Avatar
Man U FTW
Check to see if you have the backflow/check valve on the vac hose to your Master Cylinder. My buddy Zach didnt have one on his RX7....needless to say his antilag launches didnt work well. You would damn near have to be World's Strongman to hold that brake pedal down at 18psi
Old Nov 18, 2007 | 09:50 PM
panda_eh2's Avatar
what if the brake pedal does the exact opposite and when im holding the brake it slowly goes down to the floor and i have to pump it to build pressure again?
Old Nov 18, 2007 | 10:06 PM
quicksilver1689's Avatar
i ♥ snails
yeah like schister said, there is a check valve that would prevent the master cylinder from seeing positive pressure.
Old Nov 19, 2007 | 08:41 AM
95dc2teg's Avatar
Default Re: (quicksilver1689)
if u did use that brake booster vac line as a vacuum source make sure you tapped before the check valve (side closer to the intake manifold) and not after it...i dont see why there wouldnt be one there in the first place..
Old Nov 19, 2007 | 09:22 AM
foca's Avatar
yes, make sure the check valve is in and functional.
if the pedal goes to the floor there is more wrong with your brakes. master cylinder may be dead. out of fluid. and/or air in the lines.
SpeedoKing
Oct 24, 2007 11:25 AM
99teggsr
Jun 1, 2005 09:39 PM
boostin1cam
Mar 16, 2005 11:19 AM
SleepingSmurf
Aug 31, 2004 02:38 AM
civcexcoupeblack
Aug 17, 2003 03:35 PM
