VA turbo people, need in person help!!!!
Would anyone be willing to meet up with me and go for a quick ride and tell me whats wrong with my car? Its to hard to explain whats going on it with it. If you are in NOVA and willing to help me out please let me know.
Re: VA turbo people, need in person help!!!! (blackteg)
Sure. Whats wrong with it anyways?
[Modified by CRV Monster, 6:12 PM 9/13/2002] |
Re: VA turbo people, need in person help!!!! (CRV Monster)
Sure. |
Re: VA turbo people, need in person help!!!! (speedymon)
sure...
Would either of you guys (or both) be available at the begining of next week during the daytime by any chance?
The best way to describe it is a popping sound at higher boost levels. [Modified by blackteg, 12:02 PM 9/14/2002] |
piston slap?? detonation??
I am in reston in the evenings sometimes.
Re: VA turbo people, need in person help!!!! (crv monster)
i dont know if u wanna go with crv monsters decisions heheh.. he's blown quite a few things....
http://images.zeroforum.com/smile/emwink.gif RIGHT? crv? |
Re: VA turbo people, need in person help!!!! (sgT)
If you happen to be in Reston early next week would you mind looking at it?
SGT is the man.......he knows everything, hell figure it out
Re: VA turbo people, need in person help!!!! (On Point EK)
http://images.zeroforum.com/smile/emthup.gif http://images.zeroforum.com/smile/emthup.gif http://images.zeroforum.com/smile/emthup.gif Can't go wrong with Sakai diagnosing your problem.
Re: VA turbo people, need in person help!!!! (HybridKOOP)
if u do meet up with him make sure u give him some food......he ways like 105 wet http://images.zeroforum.com/smile/emthup.gif http://images.zeroforum.com/smile/emsmilep.gif
Also one other thing, about your problem... check your spark plugs and their gap. Sounds like a common "miss" under higher boost. .30 to .35 is usually good with a degree colder plugs..
Thats what I thought it was at first also. Put in a fresh set two ranges colder and it seemed a little better for a while. Most likely I was imagining it.
yeah, i can swing through there on my way home.
is it stuttering at high rpm? like poping? mine did it and i gapped the plug to .030 and turn the fuel down and now its gone. hope that helps
Two heat ranges colder sounds a little much, how much boost are you running? You're running a heat range 8 plug then? Does it miss at all at lower rpms/partial throttle? A few more details on the setup would be helpful.. Maybe you're running a little too rich? Plugs gapped too tight?
-Mike |
What would be the best way to get a hold of you sgT and set something up?
turbod16y8, yea that kinda sounds like what it is doing. SlowTeg, if I remember correctly I am running a plug in the 7 heat range. Stock for my motor is the 5 heat range. I can run 7 psi with no problems. It starts to happen when I run 8 psi or more. I am running the stock gap on the plugs. Here is my setup: B18A motor YS1 GSR tranny Quaife LSD Stock clutch w/5,000 miles 450 cc DSM injectors Zdyne Gold SECU 3 BAR map sensor MSD 6a Ignition MSD Blaster 3 coil MSD wires MSD cap NGK BCPR7E spark plugs TIAL 35mm Wastegate Greddy BOV T3/T04E Drag gen II mainifold 3" carsound cat (hollowed out not by choice) 3" Thermal Exhaust I think thats everything that could possibly related to my cars issues. As for how much boost, I am trying to run any where from 12-15 psi consistently. [Modified by blackteg, 7:57 PM 9/15/2002] [Modified by blackteg, 8:02 PM 9/15/2002] |
Re: VA turbo people, need in person help!!!! (gsrroots)
Whats does detonation sound like?
