using a 1g eclipse turbo on an h22.....stupid too small?
Old Jan 4, 2007 | 10:24 PM
deucedeuceEK's Avatar
Default using a 1g eclipse turbo on an h22.....stupid too small?
reason im asking is because I have one just laying around. I'll upgrade later when I have money too. Im pretty sure its way to small for an h22, but I wanted to get some opinions on what people think about using it first. Im only ganna use it for 5psi. waste of time? or not?
Old Jan 5, 2007 | 05:07 AM
Hulk22's Avatar
Default Re: using a 1g eclipse turbo on an h22.....stupid too small? (deucedeuceEK)
if your looking to to get your running then you will be fine. you will spool the **** out of it and your top end will be so so due to the small turbo and turbine housing. but a good turbo would be a gt30r pending on your power goals
Old Jan 5, 2007 | 07:11 AM
esedulerp5tenin's Avatar
Default Re: using a 1g eclipse turbo on an h22.....stupid too small? (Hulk22)
it should be a good starter turbo, with minimal turbo lag due to its small-ness, but will run outta breath up top
if you have the right mani, i say throw it on and see how it works
Old Jan 5, 2007 | 07:13 AM
DaveF's Avatar
Default Re: using a 1g eclipse turbo on an h22.....stupid too small? (esedulerp5tenin)
put it this way.......
id rather have a 50 shot
Old Jan 5, 2007 | 08:40 AM
turbociviccoupe's Avatar
Default Re: using a 1g eclipse turbo on an h22.....stupid too small? (dturbocivic)
the turbo is much too small.
Old Jan 7, 2007 | 01:39 AM
mr_hahn73's Avatar
Default Re: using a 1g eclipse turbo on an h22.....stupid too small? (turbociviccoupe)
I was running out of breath on my stock dohc zc by 6000rpm if that gives you an idea. I thought just putting that on my zc was a waste of time and a let down so you will be realy let down. A waste of time and money. Do it right the first time is what I live by now after that expierience with that setup!
djkina
Jan 15, 2015 12:07 PM
minime-dom
May 12, 2009 06:04 PM
cvchb91
May 5, 2005 08:26 PM
AbaZ
Sep 16, 2002 07:36 PM
