Upgraded Header Studs
Old Sep 21, 2004 | 03:38 PM
integlspwr2k's Avatar
Default Upgraded Header Studs
I was in the market for upgraded header studs and came across these..
http://www.jegs.com/cgi-bin/nc...r=361
Anyone know which one I would buy that would work on my b16?
Thanks In Advance.
Old Sep 21, 2004 | 03:50 PM
wHOAlly's Avatar
Default Re: Upgraded Header Studs (integlspwr2k)
arp makes import/honda specivic intake/exhaust manifold stud kits, goto arp website and look under sportcompact, they have like 2 or 3 lengths
Old Sep 21, 2004 | 04:31 PM
Default Re: Upgraded Header Studs (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n’d Supra &raquo;</TD></TR><TR><TD CLASS="quote">arp makes import/honda specivic intake/exhaust manifold stud kits, goto arp website and look under sportcompact, they have like 2 or 3 lengths</TD></TR></TABLE>
Thanks, i'll most definetly check that out for sure.
Old Sep 21, 2004 | 04:52 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, i'll most definetly check that out for sure.</TD></TR></TABLE>
I guess the question is why? Stock are fine and $.70 a stud.
Old Sep 21, 2004 | 06:55 PM
wHOAlly's Avatar
Default Re: Upgraded Header Studs (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
I guess the question is why? Stock are fine and $.70 a stud. </TD></TR></TABLE>
most turbo manifolds have thick flanges, the stock stud barely holds the nut, not 100% of the threads are used, on the intake side ppl use the phenolic spacers and what not, so u have the issue of it being short.
also, the stock ones, strip and stretch
and i think the arp ones come with a nut that has a smaller head, useful when u have those manifolds with large primaries that prevent the use of the flanged stock nuts
if i was simply all motor i wouldnt hasle with it or even consider it, but with the heat of the turbo manifolds, the amount of weight they hold, and the thicknesses of the flanges, i think its a good upgrade, but to each his own
Old Sep 21, 2004 | 07:14 PM
turboteg2nv's Avatar
</TD></TR></TABLE>[QUOTE=Sp00n’d Supra]
amen, brother. couldn't have said it better I'll have to check out ARP...i bought some Napa delights, we'll see how they hold up under the heat/stress. in case you're wondering, its 8mm x 1.25 pitch.
Old Sep 21, 2004 | 09:21 PM
that is EXACTLY why im looking into upgraded header studs. The intake ones Im just going to use longer honda ones. No big deal there, but spooned integra is correct, the turbo manifold i got has a REALLY REALLY thick flange, and the manifold and wastgate weight in at 25 lbs imagine a down pipe and a turbo stressing those studs even more. Scary!! im for sure going to upgrade, thanks for everyone that helped.
-Edgar-
gsrkid24
Sep 3, 2009 05:11 PM
Hondaruss
Aug 2, 2007 11:03 AM
vtekthis
Oct 1, 2006 12:50 PM
CALM_AS_A_BOMB
Jun 17, 2004 06:31 PM
Evil EG
Nov 27, 2003 04:54 AM
