Update on my sweet pea
Old Jan 21, 2014 | 03:55 PM
Snailor Built's Avatar
Default Update on my sweet pea
So alot of people have seen my car, seen my posts and also got to witness some real unfortunate luck on my side.
I was originally shooting for 7-800whp and left with a lucky 600 after the issues I had.
These were from the original issues.
So the head for some reason was experiencing valve float with PRO 1's and brand new Crower valvetrain. I ran out of duty cycle on the boost solenoid due to being lied to about the springs in the gates and the injector duty cycle was 90 something percent due to not being able to raise FP. I am running dual bosch 044s. I rewired them correctly and was going to go back and tune soon...
Then two nights after being tuned I took it to a local meet, matted it on the way home and had an oil light come on...
So now after a new head, new ATI Race damper installed... I was ready to go back.
Then loaded it on for some pulls!
Old Jan 21, 2014 | 04:40 PM
Default Re: Update on my sweet pea
Strapping it on the dyno;
294whp, 6.5psi. no vtec engaging. Then the car shut off and wouldnt turn back on , I went through the dash and such and found all of this;
andddd we leave it at this....
I found a wrecked automatic eg coupe, Im going to swap the dash harness in and go put her back on the dyno for the third time. That is the latest from my camp lol
Old Jan 21, 2014 | 05:34 PM
effin's Avatar
Keep working thru the kinks and bugs man, its all going to be worth it!
Old Jan 21, 2014 | 06:28 PM
ballistic1350's Avatar
What happened to the wires?
Old Jan 21, 2014 | 08:28 PM
turbohatch96y7's Avatar
You have the worst luck. Keep on trucking tho
Whats up with a different down pipe in each pic? haha car looks good, good luck
Old Jan 22, 2014 | 04:31 AM
I am trying, Believe you me, frustrating is an under statement.
Old Jan 22, 2014 | 04:33 AM
Schister66's Avatar
Man U FTW
Shitty luck...hopefully it turns around
The car was originally equipped with an LSTurbo running DSM 450's (Resistor box required) and I think they may have done a hack job on the wiring for the box. The more and more I look into it, its coming from that area. So again, my guess, is that there was an exposed wire, one of the wires we found on the dyno was completely bare of insulation and had corrosion all over it (Meaning it had been like that for a while). So hopefully after a fresh engine and dash harness, stock and uncut, I will wire; electric fans, dual boschs, and the gauges I am running to a separate switch panel on the audio console.
Old Jan 22, 2014 | 04:35 AM
I am running the same 4" side exit down-pipe since the turbo kit has been on the car, If you notice the pics on the dyno, its running a 90degree elbow to keep **** off my tuners walls. His shop is new and he likes to keep it looking purrrrtttty lol.
Old Jan 22, 2014 | 04:36 AM
I am certainly trying to brother thanks man.
Old Jan 25, 2014 | 03:53 PM
What do you guys think about running this panel for my pumps, gauges and electric fans? This go around I would really like to eliminate any factory wiring.
Old Jan 27, 2014 | 09:48 AM
lub's Avatar
lub
Bummer on your bad luck, good luck with everything though. Oh yeah, and that panel is pretty cool imo.
Old Jan 27, 2014 | 10:47 AM
wantboost's Avatar
Who is Mr Robot?
I'm amazed that at high rpm that elbow doesn't turn into a missile and go through his wall lol
sucks about all the issues but at least you can sort them all out. it will definitely be worth it in the end
ps that broke sticker is perfect, in both ways lol. financially broke and literally broke
Old Jan 29, 2014 | 02:58 PM
broke_page is a buddy that posts nice builds on instagram. He sent me a tshirt and hand full of stickers for allowing him to post my build.
NEWS UPDATE:
BOUGHT A KSERIES HAHA
Old Jan 29, 2014 | 03:20 PM
Charlie Moua's Avatar
wiring is a b*&@#....
glad you didn't sell the car.
Old Jan 29, 2014 | 05:26 PM
NEWS UPDATE:
Are you serious? You're gonna finish the b series build right?
Old Jan 29, 2014 | 06:22 PM
Muckman's Avatar
Moderator in Chief
Did you find out the cause of the broken oil pump gear?
Old Jan 29, 2014 | 06:26 PM
DDTECH's Avatar
How do you know, your valves were floating with pro1's and a crower valvetrain?
Old Jan 29, 2014 | 10:30 PM
wantboost's Avatar
Who is Mr Robot?
I need a broke sticker lol
dibs on the old setup
Scott.
Other Make Vehicles
Feb 11, 2014 04:05 PM
kingofbattle909
Welding / Fabrication
12
Dec 22, 2013 12:16 PM
90hatchblack
Aug 28, 2008 10:37 AM
Bjorn20
Aug 19, 2006 06:44 PM
