unplugged butterflies ok?
Old Dec 13, 2002 | 02:21 PM
Andrew 825SM's Avatar
Default unplugged butterflies ok?
I have the JG victor x IM, is it ok to leave the vacuum hoses which control the secondary butterflies unplugged from the manifold?
Old Dec 13, 2002 | 02:28 PM
falcongsr's Avatar
What is this crap?
Default Re: unplugged butterflies ok? (Airtracks)
leave the solenoid hooked up to the wiring harness and just run a short rubber vacuum line between the input and output so there is no crud getting in there just incase you wanna hook it up some day. or you can remove the solenoid altogether if you replace it with the appropriate resistor.
Old Dec 13, 2002 | 04:53 PM
B18EG6's Avatar
Default Re: unplugged butterflies ok? (falc0n)
What solenoid? Looked like a little purge valve thingee to me...know what im talking about? I have mine unplugged...
Old Dec 13, 2002 | 06:08 PM
falcongsr's Avatar
What is this crap?
Default Re: unplugged butterflies ok? (B18EG6)
...yeah you can leave it unplugged..the vacuum hoses unplugged. dont disconnect it from the wiring harness though.
you can call it a purge valve if you want.
Old Dec 13, 2002 | 07:54 PM
tony1's Avatar
Actually, you shouldn't get a cel if you disconnect the connector. I never have in the past at least.
Old Dec 13, 2002 | 10:51 PM
Flamenco-T's Avatar
Default Re: unplugged butterflies ok? (tony1)
you can unplug it and loop the remaining vaccum lines out of the IAB box...( the black plastic box)
I left the somlenoid unplugged and took the IAm box out too..
No cel
sohcvtec91hatch
May 23, 2007 09:11 PM
totsie7944
Nov 15, 2006 09:59 AM
Lewdin' Incognito
May 22, 2006 09:19 AM
preluder
Jul 4, 2003 06:55 PM
