uberdata p28 problems....not sure any ideas HELP PLEASE....
Okay where to start...
I have a p05 that is converted to a p28.
Running uberdata...tested ecu on b16 coupe for many runs ecu is perfect.
Load a h22 basemap and scale to 450's for the turbo kit......put it in the h22 car..and the car will not start, and it throws a code before it starts right away it throws a 21 vtec silanoid code. The car has a broken tps.......but that never usually made it not start, and I cant figure out why it would be that. It has a vafc in it......
I put stock p13 in it and no code 21
What would make this do this...and why...do vafc and uberdata not like each other....ecu is legit cuz it works fine on the b16 with NO cel's......so I am so lost.
And on top of all of that would a car not start just because of a 21 cel? Help please.
Also on tial wastegate's the o-ring....the smaller metal lip should face in or out on the wastegate?
Modified by gdrum at 4:19 PM 2/11/2004
I unfortunately can't help you out with the symptom, but I have to do the same thing to a P05 - how'd the conversion go? You just converted to heated 02 right? I'll be doing the same thing with my F22. Good luck.
Actually I was the one that did the conversion and it was pretty easy. Added all the vtec stuff as well as the transistor for heated o2 and no codes on my car. Grants is a different story. I haven't had a chance to get my hands dirty in it yet. So I'm helping him trouble shoot the ECU over the phone.
Luckily I don't have to deal with vtec so I think all I have to do is wire in the transistor for heated 02. I know who to bug now when I have problems
j/k
Anyway, I'd try another burn to make sure that's not the culprit - could I take a look at your bin file?
j/kAnyway, I'd try another burn to make sure that's not the culprit - could I take a look at your bin file?
jake00si
Feb 8, 2011 07:26 PM
