uberdata nokia datalogging cable work with other datalogging apps?
I'm gonna be running neptune, and was about to run uberdata...
uberdata sources say a nokia cable could help datalog.
i'm wondering if this should work with any other datalogging systems like hondata, or neptune
I think they both have there own source of datalogging and will use a 4pin header that a connectors will just plug right into, atleast hondata is that way. I think I saw the neptune is working on it or something like that. I would assume that you could use a usb to serial cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">I think they both have there own source of datalogging and will use a 4pin header that a connectors will just plug right into, atleast hondata is that way. I think I saw the neptune is working on it or something like that. I would assume that you could use a usb to serial cable. </TD></TR></TABLE>
well based on my tuner... he said it needs the same exact cn2 connector like in hondata... so i assume they work the same (as far as datalogging)
however i want to know if the nokia cable which is used in uberdata, can be used with hondata/neptune...
in theory i would think it works since its sending the same data...
In theory it should work...as long as the program is coded for it. Those CN2 pins on the connector send the identical data no matter what program is running. It's just a matter of decoding it.
teezda9
May 27, 2007 01:59 PM
