turbod sohc???
yeah my question is first how does a sohc vtec motor with a
decent turbo do on the streets , since money is a issue as with everything , not to mention everyone here is b18 this and b16 that , i just kinda want to be different. also does anyone know of where i can get a complete swap for a 92 cx. thanks for your help. |
Re: turbod sohc??? (mle_92cx)
anyone??
you need to do a stinkin' search before you get told off by someone also you wont be that different because alot of guys are turbocharging D16's now
I guess I'll answer you but I won't came back here to look at the progression of this tread.
you can get very good power out of a D engine, first of: all you will get is like 300 Hp at the very very most without putting a good amount of $ and tunning in it. you can acheive close to 200 whp with little to no tunning on a Stock block, d serie engine. they do good on the street, though, you should race at a track for security reason, i'm shure you understand that. search on this board for more info, for money reason I choosed to go D, D serie block and part's are ditched everywhere in the country, you only have to search a bit to find good, used part's, when you breack, cause you WILL, it's less troubble finding part's hope this help a bit Kranked |
Re: turbod sohc??? (Cezilla)
did search and it did not answer my question, how does it pull
on the street. only thing i see is dynod got 220hp and dynod got 190hp and so on and so on. |
it pulls pretty good if u get a nicely sized up turbo. i used a T3 60 trim and it was awesome.
Find all the answers to your questions here -> http://www.turbod16.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mle_92cx »</TD></TR><TR><TD CLASS="quote">did search and it did not answer my question, how does it pull
on the street. only thing i see is dynod got 220hp and dynod got 190hp and so on and so on. </TD></TR></TABLE> It pulls like a fwd with 220hp.. https://honda-tech.com/forums/images/smilies/emwink.gif |
