Turbo+type R cams good idea?
Old May 23, 2002 | 02:44 PM
fast[R]'s Avatar
Default Turbo+type R cams good idea?
I have a set of type R cams and a set of gsr's wich ones are more relyable with turbo. I know type R cams make more power, I will be runing around 15psi, don't know if the overlap is too much, some help guys.
Old May 24, 2002 | 02:42 PM
fast[R]'s Avatar
Default Re: Turbo+type R cams good idea? (fast[R])
Enyone?
Old May 24, 2002 | 02:44 PM
SiRkid's Avatar
YES!
go for it!
Old May 26, 2002 | 12:23 PM
fast[R]'s Avatar
Default Re: Turbo+type R cams good idea? (SiRkid)
Enyone elce?
Old May 26, 2002 | 12:30 PM
Jared's Avatar
Definitely, according to the butt dyno, I gained a ton of power over my GSR cams The Type Rs do have overlap, but they dont have as much the faster the engine turns, and a set of cam gears will let them make far more power than the B16 or GSRs.
Old May 26, 2002 | 12:33 PM
Ltech's Avatar
Default Re: Turbo+type R cams good idea? (Jared)
Do you want to sell the Gsr cams to me? email jasonphan1915@yahoo.com
Old May 26, 2002 | 12:35 PM
turbopanda's Avatar
Default Re: Turbo+type R cams good idea? (Ltech)
I have B18C-R 98spec cams in my teg with AEM trutime cam gears. It has yet to be tuned on a dyno, but from what I just read above.. I guess I should be expecting some good results
Old May 26, 2002 | 05:28 PM
SiRkid's Avatar
Default Re: Turbo+type R cams good idea? (turbopanda)
from what i know they are the best for our cars.
unless your building an all out race engine.
Old May 26, 2002 | 07:47 PM
kidkutz's Avatar
Chris Rado uses type r cams in his 8 second turbo integra
Old May 26, 2002 | 07:51 PM
Flamenco-T's Avatar
Default Re: Turbo+type R cams good idea? (kidkutz)
I have an ITR intake cam on my GS-R at 6.5 psi I made 256WHP
so if you know what average GS-R made at 6.5psi, then you can find out how much more power it can make
Old May 26, 2002 | 08:47 PM
SiRkid's Avatar
Default Re: Turbo+type R cams good idea? (Flamenco-t)
damn.i need a 1.8 block with itr cams and im set
Old May 28, 2002 | 02:35 PM
fast[R]'s Avatar
Thanks for the info guys, type R cams it is
B16CivicSi00
Oct 4, 2009 04:21 PM
khcivic
Apr 11, 2003 02:06 PM
dingusjt
Mar 23, 2003 01:30 PM
just4fun
Sep 10, 2002 12:09 PM
AK94GSR
Aug 1, 2002 03:39 PM
