TURBO TIMER ???
Old Mar 4, 2004 | 03:18 PM
gsrroots's Avatar
Default TURBO TIMER ???
I need to know how long I should set my turbo timer on my car for...I dont want to set it for too long and I definatly dont want tot set it for too short.....I know this is a stupid ques I just want to know how long you guys set your for......Let me know
Old Mar 4, 2004 | 03:44 PM
2000GSRT's Avatar
Default Re: TURBO TIMER ??? (gsrroots)
I usually set mine for 20 seconds. If I needed to run it longer than that I would just wait a little longer to shut it down.
Old Mar 4, 2004 | 08:37 PM
gsrroots's Avatar
Default Re: TURBO TIMER ??? (2000GSRT)
any one else??
Old Mar 4, 2004 | 08:47 PM
GForceInteg's Avatar
Well i have the hks with auto timer and normally on a easy drive to work (6miles) it ends up around 1 minute 15-40. However it counts up fast when excellerating. If i were to race home same distance would end at like 3-4 minutes. Just what i have found with the hks auto timer.
Old Mar 4, 2004 | 09:10 PM
DownBoyDown's Avatar
In the book, Max Boost, Corky Bell says that you only need to let your car idle for about 30 seconds. I'd just set it to 1 minute if I were you, just to be safe.
Old Mar 5, 2004 | 06:14 AM
gsrroots's Avatar
Default Re: (DownBoyDown)
I have the greddy timer and its set on 10 minutes thats way to long isnt it....
Old Mar 5, 2004 | 07:33 AM
Rod.'s Avatar
Default Re: (gsrroots)
10mins that is to long. If you want your car still on after you walk around walmart a couple of times. 1min or 1 1/2 will be fine
Old Mar 5, 2004 | 07:45 AM
green_GSR's Avatar
Default Re:
It depends how hard the turbo is working before you turbo-time your car. If you just did a fourth gear pull at 20+psi, then it's a no brainer that you should turbo-time your car longer.
Usually, before I park my car or turbo-time my car, I take it easy on the turbo. So no boosting 2-3 mins before I park my car. That way, you won't have to turbo-time your car for so long. Usually, when I did that, I just turbo time my car for 3 minutes. And if I did some heavy boosting just beforehand, I let my car turbo-time for 10 minutes.
If you don't have an oil cooler. Get one. Less heat (or more cool oil) for the engine, turbo, lubricating system, etc.
Old Mar 5, 2004 | 08:18 AM
gsrroots's Avatar
Default Re: Re: (green_GSR)
Nah the only time my will see that much boost is at the track....But thanks for the info...
Apr 2, 2005 12:08 AM
ninja8oi
Aug 8, 2004 05:22 PM
kun3racer
Mar 26, 2004 09:07 AM
Wo-Nelly
Aug 5, 2002 03:42 PM
MiraiZ
Dec 31, 2001 09:44 PM
