Turbo Setup Opinions
Old Feb 13, 2004 | 01:18 PM
Mark_DC2_NZ's Avatar
Default Turbo Setup Opinions
Hey everyone,
Ive been reading the forced induction forum for a while now, and its convinced me to look into turbo setups for my jap spec b18c ((DC2) Si Integra).
<U>This is the setup i am looking at:</U>
T3 turbo standard off nissan skyline gts-t's and gts-25t's@ 8 psi daily.
Standard b18c block and internals with compression ratio of ~10.6:1
Mitsubishi Vr4 Intercooler
Mitsubishi VR4 4*440cc injectors (flow tested etc.)
Walbro 255lph in tank fuel pump
Standard ignition system
<U>Engine Fuel Management:</U>
Either a full link dyno tuned (we have more link tuners here in New Zealand)
or Hondata s200 dyno tuned (alot more expensive to dyno tune here)
<U>The questions:</U>
Will this be a reliable setup? (as it is my daily driver)
Is it safe to run the stock compression ratio of 10.6:1? (Jap spec integra), remembering that I will be using 96-98 octane fuel.
Will the stock ignition system handle the setup?
Any other recommendations etc. would be a good help thanx.
Cheers
Mark
Old Feb 13, 2004 | 02:45 PM
swlabhot's Avatar
Default Re: Turbo Setup Opinions (Mark_DC2_NZ)
8 psi daily is a piece of cake. It can take more than that. I'm running 10psi on 11:1 cr on B18C6.
The reliability is only as good as the tune....
Stock ignition should be OK.
Old Feb 13, 2004 | 04:37 PM
b16ahybrid's Avatar
Default Re: Turbo Setup Opinions (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">8 psi daily is a piece of cake. It can take more than that. I'm running 10psi on 11:1 cr on B18C6.
Stock ignition should be OK.</TD></TR></TABLE>
Old Feb 13, 2004 | 04:59 PM
Weapon's Avatar
i thought skylines came with t25?? :S
Old Feb 13, 2004 | 05:38 PM
b18b1hmtlove's Avatar
wrong turbo
Old Feb 13, 2004 | 06:31 PM
Default Re: (b18b1hmtlove)
No, nissan sylivias and 180sx's come with a t-25.
You dont think that a t3 is the right turbo to use? if not provide an alternative suggestion please.
My reasons for choosing a t3 over the t3/t4 setup is that i wont be looking to pull massive boost for quite a long time, if at all.
The other reason is that they are plentiful and cheap around here.
Old Feb 13, 2004 | 06:52 PM
T3 .63/.60. no other T3 should ever find its way on a B series
Old Feb 13, 2004 | 11:03 PM
Thanks for that
Old Feb 14, 2004 | 05:34 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">T3 .63/.60. no other T3 should ever find its way on a B series</TD></TR></TABLE>
that sounds reasonable I would hope you were thinking 60trim too...
Old Feb 17, 2004 | 06:20 PM
Weapon's Avatar
lol sorry for being a d*ck but im positive as hell the skylines didnt come with a t3, didnt they come with a turbo similar to the t28 but was specially made for the skyline? or so thats why the ppl over at skylinedownunder.co.nz say :S and where abouts in NZ are u? im from auckland
92db2gs-r
Jan 5, 2011 11:33 PM
Johnny_Rocket
Mar 3, 2005 10:18 PM
Type-ARR
Jun 30, 2003 05:20 PM
g2_boosted
Sep 28, 2002 06:32 PM
Markaccord95
Nov 18, 2001 12:59 AM
