Turbo Rebuild options?
Old Aug 31, 2005 | 07:33 PM
nsxmatt's Avatar
Default Turbo Rebuild options?
I was planing on rebuilding a Turbonetics t3/t4 from the Drag kit. We have always shipped to cheapturbo for their rebuild but I found this from a Turbonetics dealer
http://cgi.ebay.com/ebaymotors...wItem
Would this be a option for rebuilding a turbo? As long as you marked the shaft before you removed the blades to keep it balanced it should be fairly straight forward correct?
Old Aug 31, 2005 | 09:19 PM
nsxmatt's Avatar
Bump
Old Sep 1, 2005 | 09:28 AM
nsxmatt's Avatar
Default Re: Turbo Rebuild options? (nsxmatt)
Old Sep 1, 2005 | 11:45 AM
seen4ever's Avatar
not going turbo ehhh....
I would think it would work, but then again, i would get a little timid regarding the shaft being balanced, seeing the RPMs it turns. You know Republic Diesel downtown, Louisville, KY rebuilds turbos, although I think they are primarily a garret distributor. But i know they will balance wheels and even do injector flow benching.
Old Sep 1, 2005 | 02:21 PM
EJ1 wilcox's Avatar
Default Re: Turbo Rebuild options? (seen4ever)
You have to be careful when doing it yourself.
The bearings have to be matched to the shaft perfectly. The wheel balancing isn't the only thing to worry about when rebuilding a turbo.
I rebuilt mine by myself. When I put the new bearings in the CHRA and slid the shaft through them there was too much shaft play. I had to reuse my old bearings, which was fine because the turbo had zero shaft play before the rebuild, just the compressor seal was leaking badly.
Turbo rebuild shops will actually polish the shaft, mic it, and then use bearings that fit perfectly. The bearings have to fit perfectly around the shaft in order to ensure that there is no shaft play.
Old Sep 2, 2005 | 06:30 PM
nsxmatt's Avatar
Well the kit comes with new bearings so as long as the shaft is marked, taken apart and put together the same it should be balanced I would hope.
EJ8 944
Jun 16, 2008 06:47 AM
JLAO
Feb 6, 2007 12:07 AM
NosCivic01
May 25, 2006 12:01 PM
Full-Race Geoff
Aug 31, 2002 08:19 AM
CalvitoSol
Jun 12, 2002 05:58 PM
