turbo question?
Old May 29, 2004 | 08:22 PM
........'s Avatar
Default turbo question?
would thisturbo work for my 95 d15b7? would i have to get a custom mani or something?
http://cgi.ebay.com/ebaymotors...&rd=1
Old May 29, 2004 | 08:31 PM
vtec181's Avatar
Default Re: turbo question? (95lx4dr)
you would have to ask to the forced induction guys
Old May 29, 2004 | 08:38 PM
screech's Avatar
to answer your question yes it will work for your car you will have to get a mani to fit your motor but yes it will work
Old May 29, 2004 | 11:00 PM
ZCboost's Avatar
You have to have a look at the exhaust side flange on the turbo. Most T3's use a standard rectangular 4 bolt flange. There are many different makes of exhaust manifolds with the standard T3 flange. Otherwise, it's too much of a pain in the *** to have a custom build mani.
Old May 30, 2004 | 02:10 AM
Joseph Davis's Avatar
Default Re: (ZCboost)
Dodge T3's are a bit wierd. The flange is like a normal T3 with one of the bolt holes dislocated out in left field. The turbine housing has an internal wastegate and turbine housing exit built in - the exit may not point in the direction you wish it to go. Any other OEM T3 turbine housing will fit on, if you run across one.
Keep in mind that there is no such thing as a good used turbo. No matter what line of horseshit someone tries to feed you, there are only good rebuildable turbo cores. eGay and online sales to n00bs is the #1 way of liquidating some halfassed **** at top dollar.
http://www.homemadeturbo.com is as good as HT's Forced Induction forum in a lot of ways... in other's it's better for you - the guys around here try to tell you that you have to spend a million dollars and put 600 to the ground - like that's even possible on the street.
FeedBack159
Nov 7, 2013 12:28 PM
that-guy
Welding / Fabrication
Dec 29, 2010 10:15 AM
SoHc94
Oct 12, 2008 06:36 PM
2muchPSI
Mar 5, 2006 11:33 AM
Slammd Sol
Jul 2, 2004 08:01 PM
