turbo manifolds
Old Apr 22, 2008 | 12:58 PM
civicgen3's Avatar
Default turbo manifolds
what the drifferents between the log manifolds and the ramhorn manifolds???
Old Apr 22, 2008 | 01:09 PM
beseman's Avatar
Default Re: turbo manifolds (civicgen3)
log manifolds are made out of wood and ramhorn manifolds are made out of the horns on rams' heads. the horn material is stronger than the wood, so it ends up costing more.
your welcome in advance
Old Apr 22, 2008 | 01:31 PM
civicgen3's Avatar
Default Re: turbo manifolds (beseman)
thanks really helpful.
Old Apr 22, 2008 | 02:50 PM
22's and Man Boobs's Avatar
all you need to know is ram horn>log manifold
Old Apr 22, 2008 | 05:14 PM
Schister66's Avatar
Man U FTW
All things else the same, the log manifold will spool the turbo faster due to the short runners; however, it will also lose more up top. It will effectively give you a more linnear powerband. The ramhorn has a true collector and longer runners which will increase lag; however, since the collector flows much more efficiently than the log, it will make more power up top.
Old Apr 22, 2008 | 05:19 PM
SpoolnG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beseman &raquo;</TD></TR><TR><TD CLASS="quote">log manifolds are made out of wood and ramhorn manifolds are made out of the horns on rams' heads. the horn material is stronger than the wood, so it ends up costing more.
your welcome in advance</TD></TR></TABLE>
Old Apr 22, 2008 | 06:35 PM
TheShodan's Avatar
Moderator
Now THAT's funny!!
Old Apr 22, 2008 | 09:47 PM
civicgen3's Avatar
Default Re: (Schister66)
cool thanks, just what i was looking for.
fasterthenU
Sep 13, 2007 10:59 PM
blue2000em1
Jul 9, 2007 07:57 PM
BlUAc
Welding / Fabrication
Dec 1, 2006 11:50 AM
98_accord_ex_
Jun 14, 2006 05:08 AM
skellator_thoj
May 18, 2003 07:46 PM
