turbo manifold question..
im making a custom turbo manifold out of what i had left of a greddy header, i want to make it a top mount turbo manifold, im going to cut a hole into one of the tubes and weld in a arm for a external wg, the thing is i think the only way i can mount the turbo is with the compressor side facing the transmission will i have room for a down pipe or not, this is on a crx with a b16. thanks.
kyle |
Sure...why not?
This is actually the way most turbo setups are run with the compressor closest to the tranny. |
Re: (1995Civic)
and im correct that the intake side is the compressor side right i dont want to confuse anyone lol
Re: (hondacrxb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxb16 »</TD></TR><TR><TD CLASS="quote">and im correct that the intake side is the compressor side right i dont want to confuse anyone lol</TD></TR></TABLE>
Yep. |
Re: (1995Civic)
ok sounds like it should work thanks.
In a CRX quite a few are run tranny side, however altogether very few are run that side. Just more of a hassle for the intake as well as a downpipe. Typically the ebay specials run the turbo backwards, but its all doable https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (ITS_Dunn)
yea this def isnt a ebay special lol im going to do it right the manifold is going to be crazy when im done with it.
Re: (hondacrxb16)
Post pics of the manifold. https://honda-tech.com/forums/images...s/emsmilep.gif
Re: (trashcanrepairman)
Re: (ITS_Dunn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITS_Dunn »</TD></TR><TR><TD CLASS="quote">In a CRX quite a few are run tranny side, however altogether very few are run that side. Just more of a hassle for the intake as well as a downpipe. Typically the ebay specials run the turbo backwards, but its all doable https://honda-tech.com/forums/images/smilies/emthup.gif</TD></TR></TABLE>
Mine is run tranny side and isnt an Ebay special...i can assure you https://honda-tech.com/forums/images...s/emsmilep.gif However my new setup will be the opposite https://honda-tech.com/forums/images/smilies/emwink.gif |
