Turbo, Hondata, and Full Throttle Shift Issues.
Old May 8, 2002 | 02:03 PM
HXMan's Avatar
Default Turbo, Hondata, and Full Throttle Shift Issues.
I am thinking this would be a deadly combination.
As far as I know hondata uses a fuel cut to drop rpms down when you do a full throttle shift.
With a turbo this would cause some serious detonation potential.
Am I right? Or does hondata use something like an ignition cut to limit rpms?
In hondata's little movie they say full throttle shifting is great for a turbo vehicle since the throttle plate doesn't close, and the turbo stays spooled........
Old May 8, 2002 | 04:45 PM
escapist13's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (Mad HXMan)
See below, these guys know more than me.
[Modified by escapist13, 10:47 PM 5/9/2002]
Old May 8, 2002 | 05:15 PM
dustin's Avatar
No, it cuts both on full throttle shift/launch control.
Cuts only fuel @ normal rev limiter like OEM.
Old May 8, 2002 | 06:18 PM
HXMan's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (dustin)
So I take it no one uses the hondata full throttle shift feature on their boosted vehicle? That sucks....I really liked full throttle shifting.
Old May 8, 2002 | 06:34 PM
racerxadam's Avatar
i thought that because its cuts fuel completely that it was safe. without fuel there won't be any combustion and therefor no danger. is this untrue?
Old May 8, 2002 | 06:49 PM
Rain_man's Avatar
New User
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (racerxadam)
When the fuel is cut, the mixture goes lean since there's still plenty of air around.
Old May 9, 2002 | 04:58 AM
blowncivichb's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (DarksideDC4)
When you disengage the clutch the motor isn't under load anymore...so leaning out from the fuel being removed shouldn't hurt anything.
Old May 9, 2002 | 06:59 AM
Dublocivic's Avatar
Get an MSD 6AL and use the soft touch (cuts spark).. bounce off the limiter all day if you want.
Old May 9, 2002 | 07:02 AM
HXMan's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (Dublocivic)
That is what I am thinking. Maybe I will get one this summer sometime.
Old May 9, 2002 | 07:24 AM
shadowdawn's Avatar
Mad I f-ing LOVE THAT QUOTE -If you have no lag, you have no turbo mind if I use that once in a while in explaining things to newbs in posts?
Old May 9, 2002 | 07:54 AM
HXMan's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (shadowdawn)
I have no problem.....you aren't quoting me, you are quoting corky bell.
Old May 9, 2002 | 01:30 PM
Hondata's Avatar
I think you might be confusing sitting on the rev limit with the full throttle shift.
A fuel cut is used. During a full throttle shift the fuel is shut off completely until the engine drops about 2000 rpm.
Sitting on the rev limit under boost with a fuel cut is not a good idea as the the engine is only dropping a few hundred RPM before switching on the fuel again, a much shorter period of time, and more prone to leaning.
Old Aug 26, 2008 | 08:57 AM
oranginal's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (HXMan)
briing back an old post to get some new info....
So is it safe to use the hondata full throttle shift (FTS) and launch limiter features with a turbo car or will it cause the engine to go lean and have issues? I'd rather stay in boost than deal with lag
Sounds like MSD full throttle shift cuts spark instead of fuel which sounds better but is hondata still good or is it not recommended?
Old Aug 26, 2008 | 01:59 PM
Bugermass's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (oranginal)
You could always run eCtune its got the option to do fuelcut, ignition cut, or a combination of both.. For normal rev limit, FTL,FTS, and antilag. Having ignition cut makes antilag more affective as well.
Old Aug 26, 2008 | 02:23 PM
SovXietday's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (Bugermass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bugermass &raquo;</TD></TR><TR><TD CLASS="quote">You could always run eCtune its got the option to do fuelcut, ignition cut, or a combination of both.. For normal rev limit, FTL,FTS, and antilag. Having ignition cut makes antilag more affective as well.</TD></TR></TABLE>
You can set Hondata's rev limit to cut both fuel and ignition. I don't use the FTS, it's not like you're going to be on the rev limiter for extended period amounts of time.
Old Aug 26, 2008 | 10:15 PM
rorik's Avatar
Default Re: Turbo, Hondata, and Full Throttle Shift Issues. (Rain_man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rain_man &raquo;</TD></TR><TR><TD CLASS="quote">When the fuel is cut, the mixture goes lean since there's still plenty of air around.</TD></TR></TABLE>
What mixture? You'd have just air in the cylinder for that cycle. Sequential port injection, you're either going to have fuel or not for each firing impulse..not a lean condition.
The oem rev limit is a fuel cut. With the ignition cut, you lose your tach signal, f that..
CXtypeR
Mar 19, 2007 03:55 PM
digital sol
Jul 17, 2006 03:10 PM
thrty8street
Jan 25, 2004 02:35 PM
Stock@$$GSR
Apr 3, 2002 10:30 PM
