Is This TURBO To Big ?
Old Feb 27, 2003 | 04:14 PM
mundo's Avatar
Default Is This TURBO To Big ?
I have a Garret turbo- .60 AR is on the compressor side and . 82 on the turbine side. Its a good turbo no end play on shaft ...I got it for free ...and want to slap it on my LS engine . Is the LS engine too little of a displacement ? Or should i try putting it on something higher ( Plelude, Crv). .........
Old Feb 27, 2003 | 04:28 PM
92JDMSiR's Avatar
Default Re: Is This TURBO To Big ? (mundo)
thats pretty big for a street car
Old Feb 27, 2003 | 04:32 PM
Speed PHreak's Avatar
What trim is the compressor? If it's a (60 trim)t4/t3(.82 A/R) then thats a rather large turbo to be putting on stock LS engine. It'll make a good amount of power for you if you're built and can rev higher. But you prolly won't get spool till the 5000RPM range. You could use is on something larger like a 2L LS/GS-R or an H22 and it would spool a bit earlier....
Kinda large, hope it's not for stock/street use. I'll trade ya my 54trim -.63 A/R for it
Old Feb 27, 2003 | 04:44 PM
Canuk_SiR's Avatar
Default Re: Is This TURBO To Big ? (Speed PHreak)
I'd say its too big for a LS.
How much psi are you looking to push?
Old Feb 27, 2003 | 05:03 PM
baddassduramax's Avatar
Default Re: Is This TURBO To Big ? (Canuk_SiR)
got it for free? i would sell it and buy a t3/t04e .63 a/r turbine housing..IMO or the t3/60-1
Old Mar 3, 2003 | 02:06 PM
mundo's Avatar
Yeah your right its too big. Ill try to sell it and get a smaller one .
Old Mar 3, 2003 | 02:12 PM
InfamousRS's Avatar
Would the t3/60-1 .63 spool faster than a t3/t04e .82? Which would produce more power on the exact same setup? Would the power bands be the same?
Old Mar 3, 2003 | 02:30 PM
mundo's Avatar
The inlet on the turbine is a triangle three bolt flange . Since i havent seen any 3 bolt flanges , i was wondering if it would be hard to find a manifold?
SiR99
Apr 19, 2010 09:25 AM
Scotty Dosent Know
Aug 2, 2006 05:04 PM
ThrowSomeDs
Dec 15, 2004 07:46 AM
VNTEC
Jun 2, 2004 11:13 PM
HybridCoupe
Jul 17, 2002 03:38 PM
