tubular manifold compatibility ?
I couldn't find just the answer I was looking for anywhere on here..so i'll just post this and ask.
I have a 98 GS and have a Drag Gen III turbo kit. If I replace the Drag manifold, for a tubular one...will my downpipe still work and will i be able to use the drag intercooler piping ? or will i have to get some custom stuff done ?
yea maybe a spark one will come close, but it wont be dead on .
usuallt tubular ones will bring the turbo away from the block more.
just mod the dp a little, shouldnt be too bad depending on the manifld.
Thanks guys. where can I find this Spark stuff ? Maybe i'll give that shot and see how close I am...then go from there.
Thanks for all the info!
Well thats just it I would not pay for a spark one. I would stick with your drag setup till you can afford a nice tubular and a 3" dp to go with it. There are several ac compatable versions and there is soon to be another..
If you get a spark manifold get ready to brace it. You will have more problems in the long run. Just get a really good tubular manifold. The SST from lovefab.com is affordable and just get the right downpipe for your setup. The downpipes are only 175.00 bux. You will have a beefy manifold that will flow well and is made out of a much thicker material.
well i guess the lovefab mani will probably be my choice then. I dont have to worry about ac compatibility...becuz i have already removed that from my car. is there a variety of downpipes i can choose frm at lovefab ? i'll have to check them out. I still have the t3/t4 from the drag kit, and i am going to use it, but it has that weird 5 bolt pattern on the exhaust. i will either have to get a flang and weld it to the new d.p. or get one that is already setup for that.
thanks again for the wealth of info here.
boosted_dc2
Nov 16, 2003 12:04 PM
