Troubleshooting: Spark keeps blowing out
Old Nov 9, 2019 | 04:32 PM
hatchizzle's Avatar
Default Troubleshooting: Spark keeps blowing out
I have a 96 b18c ITR, wiseco 9:1 pistons, eagle rods, pt5831 turbo, e85, id1000 injectors, hondata s300, bkr7e plugs gapped to .018, 11psi roughly boost
I just got everything together and i was noticing when i originally gapped plugs at .028 i couldnt go above 5k rpms before breaking up. I lowered gap to .020 and now i can rev to 6.5k before breaking up. I tried .018 but it feels the same.
Cap, rotor are new OEM honda, wires are NGK blue a few months old, not sure if something else is wrong causing me to need to decrease the gap even more. Let me know if you have any advice.
Old Nov 9, 2019 | 07:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: Troubleshooting: Spark keeps blowing out
It shouldn't be gapped that tight for only 11psi. Do you have an OE distributor or an aftermarket replacement ?
Old Nov 9, 2019 | 08:06 PM
motoxxxman's Avatar
sounds like your coil is dying. Buy a new oem coil
Old Nov 10, 2019 | 04:56 AM
hatchizzle's Avatar
Its an OEM distributor, it has a newer OEM coil from about a year ago.
Old Nov 10, 2019 | 05:00 AM
hatchizzle's Avatar
I am thinking of just going hondata cpr... and being done with it..
Old Nov 10, 2019 | 05:58 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I just lowered my gap down to .018 this week after blowing the spark out at almost 30psi, I had been gapped at .023 before that and was at .028 up to 15 psi. Blow out is not your issue, you sure your not leanning out?
Old Nov 10, 2019 | 06:14 AM
hatchizzle's Avatar
AFRs are mid 11s in boost.
Old Nov 10, 2019 | 08:16 AM
hatchizzle's Avatar
Checked bat voltage and is normally about 14v, at WOT dips to 13.5v, i assume thats fine.
Old Nov 14, 2019 | 07:20 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
There should be voltage offsets in the programming, but in that voltage range there shouldn’t be too much fluctuations I wouldn’t think
Old Nov 14, 2019 | 07:21 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Also might want to swap out the igniter in the distributor
Old Nov 15, 2019 | 02:32 AM
NVturbo's Avatar
O.G. triple O.G.
OEM or Genuine Honda coil? OEM is not the same as factory part.
Old Nov 15, 2019 | 05:01 PM
TheShodan's Avatar
Moderator
There's nothing wrong with supplementing mJ of energy by using an MSD or Mallory ignition system, without going to Coil-On-Plug. (And a Hondata one at that....)
Old Nov 17, 2019 | 05:31 PM
hatchizzle's Avatar
Its a geniune honda coil as far as i know, from JDM motor.
I have bee researching and thinking about going m&w pro 10 with t1 harness. All these distributor parts are so old, and new OEM parts are very expensive if you can find them.
Old Nov 17, 2019 | 07:22 PM
TheShodan's Avatar
Moderator
Again, you don't need to go as far as M&W Pro1. you can keep it simple.
Old Nov 18, 2019 | 03:36 AM
1HGEJ2's Avatar
Default Re: Troubleshooting: Spark keeps blowing out
did u try another spark plugs?? iridium are best
Old Nov 18, 2019 | 04:44 AM
hatchizzle's Avatar
TheShodan,
Do you mean just getting a cheaper ignition then the pro10?
1HGEJ2,
I tried BKR8EIX at .025", same thing happends
Old Nov 18, 2019 | 10:21 AM
TheShodan's Avatar
Moderator
TheShodan,
1HGEJ2,
Yes. Keep it simple with Mallory or MSD system with an external coil
Changing to a heat range of 8 will cause idle issues, even if you weren't still blowing out spark. changing heat ranges doesn't change the amount if mJ of spark.
Old Nov 19, 2019 | 06:20 PM
hatchizzle's Avatar
What is a reliable external coil you would recommend?
Old Nov 19, 2019 | 09:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
MSD Blaster SS.
B_Swapped93
Jun 9, 2014 09:17 AM
SR20 Inside
20
Mar 19, 2007 11:00 PM
type B16
Oct 15, 2006 12:10 PM
tca0bell
70
Sep 7, 2005 06:33 AM
SHystrdyGSRtdy
Feb 17, 2004 07:54 PM
