trap speed???????
Old May 12, 2002 | 10:54 PM
boostinb18's Avatar
Default trap speed???????
ok guys i gteched my b18b turbo crx tonight, i spun my tires threw first and then threw second......and i pulled a 15.00@99.9 mph.....what times should i be pulling with slicks????
what time will i be at with that high of a trap speed???
thanks guys!!!!
Old May 12, 2002 | 11:08 PM
boostinb18's Avatar
Default Re: trap speed??????? (boostinb18)
ohhhhh yah and i have a 15g greddy turbo on my car now.....i wanted to know if a 18g would be a good choice or would that be too big???? thanks again!
later!
Old May 12, 2002 | 11:13 PM
SEFIxCivic's Avatar
high 13's
Old May 12, 2002 | 11:17 PM
boostinb18's Avatar
Default Re: trap speed??????? (SEFI8LOxCivic)
ohhhhhh ****! tight.......do you think it will lower my trap or raise it with the slicks on??? what do you guys think of the turbo upgrade??? maybe a different turbo?? and will it bolt up to my manifold???
thanks a lot!!!
Old May 12, 2002 | 11:23 PM
SEFIxCivic's Avatar
i think you should try and work with what you have. bring it to someone in your area that knows how to tune cars and put it on the dyno to smooth and heighten your powerband. a turbo crx with an ls motor has a lot of potential. my buddy used to run consistant mid tweleves with a drag kit and that same motor with nothing else but slicks. granted your turbo is smaller, but it should have no problems getting into the 13's since your car is light.
Old May 13, 2002 | 12:16 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I think you should just spend time practicing on driving technique.
typer rick
May 6, 2004 11:04 AM
ExtremeImportRacer
Sep 3, 2002 07:59 AM
Anoesis
May 26, 2002 04:17 PM
