Traction problems!!!!
Old Jan 24, 2005 | 01:51 AM
JDM97R's Avatar
Default Traction problems!!!!
Hi guys,
Can you give me some oppinions about my set up:
I have a type r turbo engine with about 350 bhp with jdm 96 spec tranny with a 4.785 fd and 205/60/16 toyo t1s tyres(24.1 inch)
What do i have to do to improve traction?
I use for street and strip so no slicks.
I have already mugen motor mounts with es inserts and spoon progressive springs.Thanks.
Old Jan 24, 2005 | 01:58 AM
TeStUdO's Avatar
Traction bars and drag radials would help. Stiffer springs as well. You already have an LSD I suppose.
Old Jan 24, 2005 | 02:00 AM
rhamlinii's Avatar
Default Re: Traction problems!!!! (JDM97R)
Hmmmmm, a gear dependent boost controller and some meatier sticky tires could help. I wanted to be a smart *** and say "take the turbo off", oh well.
Old Jan 24, 2005 | 02:06 AM
JDM97R's Avatar
Default Re: Traction problems!!!! (rhamlinii)
Yes i have already a lsd.I'm going to buy some drag radials this week.So what about my traany set up,should i change something in it?
Old Jan 24, 2005 | 06:50 AM
Boltz's Avatar
The only thing for traction you could do for your trans is a longer final drive.
Traction requires, proper suspension, (traction bars, duh), and drag radials.
If you do all that you will notice a GREAT improvement in traction
Old Jan 24, 2005 | 06:55 AM
Slammd Sol's Avatar
Welcome to a high HP FWD car, where traction does not exist. I'd suggest picking up an AVC-R which has the gear dependent boost. Turn boost down low in 1st and 2nd gear and you'll do better.
Old Jan 24, 2005 | 08:28 AM
PrettyLude's Avatar
besides getting the avc-r you can get the blitz twins that will do the same thing
wfocrx
Jul 30, 2014 07:18 PM
JDM97R
Suspension & Brakes
Jul 25, 2007 10:28 AM
nanokpsi
Feb 20, 2007 09:34 AM
dirtySOHC's
Aug 18, 2005 06:50 PM
TypeR1558
Aug 12, 2002 06:58 PM
